How to keep electronics dry???? - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Seaplanes E-Powered Discuss electric powered seaplanes here
Old 11-17-2009, 05:07 AM
Henry111
Publisher, Electric Flyer Magazine
Henry111's Avatar
Default How to keep electronics dry????
I am preparing to purchase a Seabee Twin from G&P Sales. I have no experience with seaplans, so I am very concerned about keeping the electronics dry--while at the same time providing sufficient cooling. As you probably know, the single-engine Seabee is a pusher. But on the twin, the motors (mounted on the wing) face forward in the "normal" fashion. My tentitive plan is to put the batteries in the fuselage, and the ESCs behind the motors in the motor pods. This Seabee twin has a 72" wing span. Any suggestions for keeping "stuff" dry and at the same time provide cooling will be sincerely appreciated.
You can see photos of the model at G&P Sale here:
http://www.rcairplane.net/index3.html
Henry111 is offline
Old 11-17-2009, 07:19 AM
Larry3215
Look out for that tree!!!
Larry3215's Avatar
Hi Henry,
I highly recommend using a product called CorrosionX.
No matter how hard you try to protect your gear - condoms, balloons, baggies, hot glue, etc etc - if you end up going down in the water it will get into something and kill it.
I have tried every option over the years and then I read about CorrosionX, tried it and have never even considered going back.
Check out my post #3 in this thread for a full discription of how it works and how to use it.
http://www.wattflyer.com/forums/showthread.php?t=26120
Trust me, if you do it correctly you will never have to worry about blowing an ESC or Rx by dunking in the water again. I have actually ran motors, esc's, rx's while they were under water.
The old TV commercial for this product shows them treating an old tube type TV set. Then they plug it into an extension cord and toss it into a swimming pool. Some diver is then shown watching tv under water.
I treat everything EXCEPT servos. Some guys have reported that they open up the servos and treat only the circuit board. Thats too much trouble for me. I have had servos quit while they were wet but they have always come back after drying out.
The stuff works.
Larry3215 is offline
Old 11-17-2009, 06:19 PM
Henry111
Henry111's Avatar
Default Keeping electronics dry.
Larry, thanks.
After I posted my question I discovered your post on the question. Big relief for me.
Thanks again.
Henry
Henry111 is offline
Old 11-17-2009, 07:34 PM
Larry3215
Larry3215's Avatar
Be sure to thourghly coat every sq mm of all sides of the circuit boards.
The only time I had a failure, the tech at Castle told me I had missed a spot on the BEC circuit - and thats the part that failed.
So dunk and re-dunk and swirl and be sure the CorrosionX gets everywhere
Good luck!
Old 11-17-2009, 08:10 PM
Henry111
Henry111's Avatar
Larry, one more question:
Before treating the ESC do you remove the factory shrink wrap?
Henry111 is offline
Old 11-17-2009, 08:29 PM
Larry3215
Larry3215's Avatar
That would probably make it easier but I never do. If you have more heat shrink to replace it afterwards I dont see it being a problem though.
One good reason to remove the shrink it that velcro would stick to it much better if it wasn't coated with CorrosionX.
Old 11-18-2009, 02:09 AM
Henry111
Henry111's Avatar
Larry, regarding velcro sticking. That is a thought because I alway use it to mount my ESCs. So take off the factory shrink wrap. Treat with CorrosionX. Then put on new shrink wrap?
Henry111 is offline
Old 11-18-2009, 03:02 AM
Larry3215
Larry3215's Avatar
I see no problem with that.
Old 11-18-2009, 04:58 PM
MaxAdventure
AMA 198798
MaxAdventure's Avatar
Default Corrosion X alternative
Well Larry, you really have some great information, suggestions, etc you've shared over the years and I really appreciate it!
I read some of your threads on the Corrosion X and realized I'm LONG overdue for using it. I have a cub I've started float flying, started a PBY5A project and I'm thinking about a Mars project next year.
At any rate, I looked all over Ace and couldn't find any, managed to get to the infamous McGuckin's Hardware in Boulder (they have everything, like - really everything) http://www.mcguckin.com/ and still couldn't find it, but I did find Boeshield T-9 developed by Boeing that seemed like the same stuff (and a couple of other corrosion inhibitor brands) decided if it was good enough for Boeing, might be good enough for my planes.... kinda hurt at $20US for a 16oz and $10 for the 4oz. I decided the 4oz would last me for some time and took it home.
As usual, I did my post purchase shopping research and found this which I thought was really interesting:
http://www.thehulltruth.com/boating-...rrosion-x.html
My take away is that probably all three products work, and concidering my receiver is not exposed to the elements, I wouldn't be able to tell which worked 'best', but as long as it saves me RX and ESC, I'm happy! I'm curious if anyone else has an opinion between them, or Larry if you've tried the others for our applications.
Thanks again for the advice Larry!
MaxAdventure is offline
Old 12-06-2009, 03:06 PM
donjiskra
WAA-08 Pilot
donjiskra's Avatar
Corrosion Block
This is a new product to me, so I looked it up:
http://www.nocorrosion.com/how-corro...trol-works.htm
Sounds good and I like the fact that it doesn't leave a "gummy residue" unlike Corrosion X
A 12oz spray can costs $15.00 and a 6oz is $7.00
Mailing Address:
Midwest Corrosion Products
2813 193rd Street
Lansing, IL 60438
donjiskra is offline
Old 12-06-2009, 04:13 PM
Modifier
"Bank and yank"
For sealing servos, I have used "Tool dip" that has been thinned down.
http://www.toolmarts.com/performix_18Z01.html
Dunk (or brush) the servo right up to the output shaft area, but not on the shaft or splines obviously.
For sealing the output shaft/case gap, you can spread a big bead of dielectric grease (or your favorite) around that area, then push your servo horn on. It probably wont completely seal from extended immersion, but it will withstand splashes and dunks.
I know what you are going to post, "the grease will cut once the servo turns", but as the servo turns back, it smears the grease back the other way. It lasts for a suprisingly long time before you need to reapply.
I have done both tricks for years for boats and trucks, even with O-ringed servos, both ideas have worked good and saved me money.
Modifier is offline
Old 12-06-2009, 08:21 PM
Moxus
Gremlin
i use condoms, then put a splash of silicone around the wires there they enter the condom, and then a strip around the outside.
that is, unlike most other methods, absolutely watertight. you can dip it in water and your electronics stay dry.
this dont work for servos of course, but you can save your reciever this way, and esc too.
just make sure you got a safety margin on the esc rated power, to the actual power draw. that will make up for the loss in cooling.
another option i havent tried in rc, but i know it works from other electronic applications is plastic paint.
in electronics stores (not those that sells you tvs. those that sell you individual transistors) they got spray bottles with plastic paint, to protect electronics.
thats absolutely watertight, and a printed circuit sprayed with that will work evne if submerged in brine.
again, this probably wont work on servos, because you cant protect the pot meters and motors inside the servo with this.
Moxus is offline
Old 12-06-2009, 08:58 PM
Larry3215
Larry3215's Avatar
MaxAdventure and Don - that Corrosion Block stuff sounds interesting. I may give that a test one of these days. Lets us know how it works for you.
If you have a spare esc you dont mind the risk of loosing - try running a motor while the esc is under water. I know that test works with CorrosionX
Moxus - you need to be sure your using a silicone sealant thats certified safe for electronics. If not - the fumes can damage the printed circuit boards. Dont use normal household silicone sealants like you get from the home improvement store.
You also need to be carefull as you can still get condensation inside your condom/balloon when the thing hits cold water. Many guys who use that technique also put water absorbent beads in with the rx/esc.
I have not found that technique to be very reliable when I tried it - especially around an rx with lots of servo leads, but maybe I wasnt carfull enough sealing.
Old 12-07-2009, 01:02 AM
nascarwings
nascarwings's Avatar
this is all i use.... http://www.mgchemicals.com/products/...1d25e1ca769edb trust me its been well tested ...lol. i have corrosion x it works but it is a mess to work with....
nascarwings is offline
Old 12-07-2009, 07:30 PM
cyclops2
Originally ALL pcb when completed were sealed with either Varnish or Shellac. For military specifications.
Rich
cyclops2 is offline
Old 12-26-2009, 05:40 PM
cyclops2
Default How do know they used those 2 ?
Because I am older than both of them. And they were too young to remember.
Rich
cyclops2 is offline
Old 01-19-2010, 03:09 AM
AirmanAirhead
Did that tree move??
AirmanAirhead's Avatar
I like the idea of coating the esc especially with either plastic paint mentioned by Moxus, or the shellac/varnish. I've used Corr X. and I've had mixed results, but I fly in brackish water and I know that creates much more problems that fresh water. My most recent experiment is using a Turnegy ESC leaving the shrink tube on, and blocking the ends with hot glue. Since it's winter, I don't have a cooling problem, the summer will be a different deal. Having said that it's hard to argue with Larry, he seems to be the man. But again my issue is the brackish water.
AA
AirmanAirhead is offline
Old 01-19-2010, 06:36 AM
MaxAdventure
AMA 198798
I've been flying in the snow and started applying the Boeshield T-9 to my exposed ESC on my Swift II (first use of the T-9). It's right on the bottom and I had to pull off the shrink to re-solder the signal lead that ripped free so I'll be dunking it in the snow every missed catch - I'll holler if the Boeshield doesn't work. This seems as good a real-life test as any!
Old 01-19-2010, 07:04 AM
Larry3215
Larry3215's Avatar
Keep us posted MaxAdventure.
Don Jiskra - how is that Corrosion Block stuff working out?
Rolling Thunder
Off Topic Chit Chat
11
10-19-2009 07:37 AM
Rolling Thunder
Batteries & Chargers
26
10-04-2009 04:42 AM
dev
03-03-2008 09:43 PM
DavidCYWPilot
11-18-2006 12:53 PM
RogerQ
05-30-2006 06:51 AM
Quick Reply: How to keep electronics dry????
Page generated in 0.13949 seconds with 12 queries
