Seaplanes E-Powered Discuss electric powered seaplanes here
Hobby King Cessna 180 with lights / floats
Old 07-10-2018, 04:53 PM
Default Hobby King Cessna 180 with lights / floats
Hobby King used to sell a Cessna 180 with float kit ... small size of about 920mm span
It has lights in nose and wing tips, flaps etc ... also supplied with wheeled U/C for land use. Best described as a slightly smaller Skyartec Cessna !
I never had any luck getting this baby of the water. The floats would dig in and spray up into prop ... tried everything ... floats back .. fwd ... greater angle between floats and fuselage ... nothing worked.
On land it was nearly as bad ... it had a terrible habit of taking off and then having a mind of its own ... usually ending up with a nose into the dirt.
I'd like to know if ANYONE ever had any success with it ?
I've dug it out again for a possible rehash ..
Old 07-10-2018, 11:23 PM
probably needs those little flares around the front of the floats like a boat has to direct the water out instead of up and keep it away from the prop. Cut up some old credit cards and splice them in.
Like the bush Mule has
Old 07-11-2018, 09:40 AM
Funny you say that .... I took 3mm Depron strips and glued them round as spray rails to the front sections. Didn't work ... maybe because they have no 'rail' form to them.
Card strips ..... mmmmmm
19
08-21-2016 08:39 PM
Jim Casey
Seaplanes E-Powered
07-28-2012 01:14 AM
frenchstan
Pusher Park Jets
01-30-2012 05:11 AM
tallflyer
Company Discussions
04-12-2011 02:10 AM
Quick Reply: Hobby King Cessna 180 with lights / floats
Page generated in 0.05791 seconds with 13 queries
