Skyfly I6 help
Old 01-04-2018, 11:38 PM
HO-229
PROVERBS 27:17 ROGUE!
HO-229's Avatar
Default Skyfly I6 help
Background:
I have a Skyfly I6 TX and some generic 30 amp China made ESC
1) All (several) of the ESC cut out at approximately 50% throw on the TX
2) I have calibrated the Throttle min-max with the TX
3) Does the TX monitor current or some ESC value?
Anyone seen this issue and if so how did you resolve it?
I could adjust the end points but that seems silly
Thanks in advance!
HO-229
HO-229 is offline
Old 01-05-2018, 03:21 AM
Stay Quiet
Stay Quiet's Avatar
You may want to re-post this (or ask an administrator to move it) to a more appropriate forum like RC Radios, Transmitters, Receivers, Servos, gyros.
Stay Quiet is offline
Old 02-02-2018, 11:47 AM
Emilinoz
HO- i would try another ESC mate. Also check wat voltage the ESC excepts.Its a case of elimination,if you change ESC and fixes the problem then you know the fault is with the china made ESC. Something also to look at is,have you ever updated the Firmware on the TX? Have a look at the manual for the TX and maybe try a factory Re/Set it may help.Emil BTW I have the Turnigy TGY I6 TX -excellent radio!
Emilinoz is offline
Paul80
05-08-2016 06:08 PM
Paul80
11-26-2015 05:17 PM
Paul80
11-02-2015 04:56 PM
Paul80
09-21-2015 10:17 PM
parkham
07-07-2015 10:26 AM
Quick Reply: Skyfly I6 help
Page generated in 0.05574 seconds with 13 queries
