Flight Simulators Discuss computer flight simulators here
K450 quadcopter help!!!!!
Old 08-11-2014, 03:01 AM
Mrmo122
Default K450 quadcopter help!!!!!
Hi there I got a k450 quadcopter kit off eBay with moters esc and kk2.1 flight control bored put it won't take off need help setting it up if there is anyone from birmingham uk that can get this to fly for me I am willing to pay for your time plz plz plz help thanks mo
Mrmo122 is offline
Old 08-11-2014, 03:17 AM
Flubber
Flubber's Avatar
Not local but I may be able to help if you explain the problem. I fly that board in a few quads
Flubber is offline
Old 08-11-2014, 03:20 AM
Mrmo122
The thing is it was flipping over on take off so looked online and someone sec calberate the escs with board so I did that now it won't take off ?
Mrmo122 is offline
Old 08-11-2014, 03:38 AM
Flubber
Flubber's Avatar
If it flips on take off one or more of the motors/props is going the wrong direction or connected to the wrong input.
1. Take the props off and place an inch long piece of masking tape on each motor shaft.
2. power up the board and go to the motor layout screen. the correct rotation for each motor will be shown. Write this down. Close the menu and arm the quad bring the throttle up and watch the motors one by one. If it is not turning in the correct direction reverse two wires between the ESC and the motor. Recheck rotation.
3. When all the motors are turning in the correct direction and with the props still off. Arm the quad and pick it up hold it level. If you do this with the props on you are on your own. Bring the throttle up to half, All motors should start at the same time and be turning at the same speed. Tilt the quad forward and the forward motors should speed up. Tilt it back and the back motors should speed up. Do the same for left and right. If all of this checks out it is time to disconnect the battery and put the props back on.
4. make sure the prop is pitched up in the direction that the motor turns.
All the props should have the writing up. Each adjacent prop will have the reverse pitch. Arm and it should fly. If not place on a level surface and calibrate the sensors in the board. Good luck. Don't fly too high (1 meter) until you get the gains set for your quad.
Flubber is offline
Old 08-11-2014, 03:42 AM
Mrmo122
I will try that now thanks terry where are u from if I may ask
Mrmo122 is offline
Old 08-11-2014, 04:11 AM
Mrmo122
I did as you sed it still won't lift off the ground
Mrmo122 is offline
Old 08-11-2014, 04:33 AM
Flubber
Flubber's Avatar
I am in Delaware What exactly is it doing ?
Flubber is offline
Old 08-11-2014, 04:47 AM
Mrmo122
It's Reving up but not lifting up at all
Mrmo122 is offline
Old 08-11-2014, 12:59 PM
Flubber
Flubber's Avatar
Props/motors must be backwards. They are pushing air up instead of down. Double check the motor direction and the prop pitch. The leading edge of the prop going forward will be higher than the edge at the back. Easy mistake
Flubber is offline
Old 08-11-2014, 02:54 PM
Mrmo122
On my props it say 1045 and on the over it says 1045r what is cw and ccw
Mrmo122 is offline
Old 08-11-2014, 03:25 PM
Mrmo122
Ok I got it to lift off but it went to my right and crashed
Mrmo122 is offline
Old 08-11-2014, 03:33 PM
Sounds like someone is extremely new to the RC and quads....
The 1045 is the prop size......10" diameter 4.5 degrees of pitch.
The R represents reversed....you should have two with an R and two without......
The CW...CCW represents the material they are made of....some kind of carbon fiber/poly blend.
Your air craft manual should state which two (R) props are mounted where.......stock, the prop sizes are generally 8x4.5.......wonder why yours are much larger....?
If this is an ARF or semi scratch build.....best advice anyone can give a newbee for quad (or any RC) info is to seek the help of an experienced quad guy in person...hands on. Your in for a very long and frustrating experience otherwise......RC forums will only take you as far as your ability and understanding grows, which could end up doing more harm than good.....
This thread really needs to be dealt with in the Multi-Rotor section....not flight sims.....
Old 08-11-2014, 05:54 PM
Mrmo122
I have put it there aswell and also That's how I got it
Mrmo122 is offline
Old 08-11-2014, 06:01 PM
Theplumber
"The CW...CCW represents the material they are made of....some kind of carbon fiber/poly blend."
You sure cw does not stand for clockwise and ccw stand for counter clockwise
Theplumber is offline
Old 08-11-2014, 06:09 PM
Mrmo122
Yes they do I got it to lift but the quad flys to the right for some reson
Mrmo122 is offline
Old 08-11-2014, 07:02 PM
Yes, CW relates to the "clockwise" rotation and CCW relates to the "counter clockwise" rotation direction each of the motors turn with multi-rotor props......the "material" aspect was related to CW "consistant weave" or "carbon weave" referred to by many related to carbon fiber material used in automotive and aircraft industry....my bad, thought CW & CCW were obvious common terms used with multi-rotor spin direction.
Old 08-11-2014, 07:26 PM
Mrmo122
I know that mate
Mrmo122 is offline
Old 08-11-2014, 09:04 PM
Flubber
Flubber's Avatar
Make sure all your radio trims and sub trims are set to zero. Power up the quad enter the menu and move to the receiver test screen. Now you can trim the channels until they show zero. This could be the problem or the channel could be reversed or the acc could need to be calibrated.
After the receiver test, set the quad on something level and calibrate acc. Then power up in a safe area. Bring the throttle up to just before liftoff. Now you are going to check your channel direction. Gently move the stick left and the right motors will speed up. The right side may lift up, just move the stick back and it will settle. Be gentle and check all channels this way. Rudder is not easy to check this way but all the other channels can be checked.
If it flies level now you are ready to start working on the gain settings. If it still goes right add left trim. Lift off a foot or so. If it is still going right add more trim. Repeat
I am assuming that it is moving right sideways and not turning right. Your descriptions of the problems are very sparse. More information would help.
Flubber is offline
Old 08-11-2014, 09:36 PM
Mrmo122
Yes it is moving to the right even if it's no stick input
Mrmo122 is offline
Old 08-12-2014, 02:43 AM
Flubber
Flubber's Avatar
Have you tried to calibrate the accelerometer? Have you checked the receiver test screen? If yes next check balance point. Your quad may be heavier to the right.fix the imbalance if you can.
Use trim (left trim) to stop the right movement. Do this first with self level off.
Try little hops. Power to lift off use left roll to control drift and notice how much stick input is needed to control drift. Land adjust left trim and take off again, now less stick input should control drift. You repeat this process until it drifts very slowly, not at all or drifts left. Then I use the radio menu to set subtrim for that channel and return the trim lever to center and test again. If this process is doing nothing something else is wrong. If it does work you are getting somewhere.
Flubber is offline
old4570
Multi-Rotors
10-10-2014 04:24 PM
pexi1982
Video Parking lot
11-03-2013 07:50 AM
zazkapulsk
Multi-Rotors
03-09-2013 07:15 PM
slim
07-01-2012 04:31 PM
Quick Reply: K450 quadcopter help!!!!!
Page generated in 0.13095 seconds with 12 queries
