#35 Model Airplane Building Clinic >> DJAerotech Chrysalis 2m Electric Sailplane
Old 05-03-2015, 03:31 AM
  #551
Larry3215
Look out for that tree!!!
Larry3215's Avatar
Originally Posted by FishHawk View Post
Perhaps this will clear up the confusion. Because of the confined space in the fuse and having a long battery I don't have that much room to move the battery to get the proper CG. I probably have only about two inches of space to move the battery. Therefore, battery placement is critical for my situation in getting the correct CG.
FishHawk
FishHawk - hows your build going?
Larry3215 is offline
Old 01-06-2019, 10:15 PM
  #552
Stevephoon
Stevephoon's Avatar
I had a message about this plane so I thought an update was in order. The plane is still flying well. The only change to it was to recover most of it. The trans purple faded so badly it was almost pink and it was patched in enough places that it was time. I went white orange and black. (Black on the bottom only.)
I had some good flights this year! Here's one.
Stevephoon is offline
Old 01-18-2019, 02:36 AM
  #553
Captain Sid
Thanks Steve for all the help! I've got all the bits and pieces collected and should receive the kit this week. This thread has helped prepare me and I'm pretty excited to get started..
Captain Sid is offline
Old 01-19-2019, 02:41 AM
  #554
Stevephoon
Stevephoon's Avatar
Captain_Sid, No problem! Please feel free to post any progress and/or questions that you have. With everyone here at WattFlyer I'm sure we can answer almost any question.
Old 08-07-2019, 01:44 PM
  #555
Jondon51
Default Trimming a sailplane
Hi, I am jondon51, and have just joined from the uk. Sorry if this is the wrong place to ask this question. I bought a 3 meter sailplane from hyper flight in the uk . Went together nicely . So I went for the maiden flight . It is electric and launched it the model is rudder and elevator with spoilers . The cog was a bit nose heavy. The problem is that it takes about 2 or 3 seconds to start to turn . No idea what could be wrong . If the cog is too nose heavy will that cause a delay . I have asked the German maker what are the correct angles on the polyhedral wings but they have not replied yet ...any help would be very much appreciated . Thanks. John
Jondon51 is offline
Old 08-08-2019, 03:31 PM
  #556
Stevephoon
Stevephoon's Avatar
Hi Jondon51,
1st. let me state that I am not an experienced glider pilot. The Chrysalis is my only glider. My glider will not turn on a dime like a Sport plane, but 2 to 3 seconds sounds long. I assume you see that the control surfaces respond as expected on the ground and have enough throw. I would correct he CG. I correctly balanced plane will respond better than one that's not.
Is the response the same in both directions? A twist in my wing will cause mine to turn better in one direction as compared to the other.
Let us know what you find out.
Old 08-09-2019, 06:15 PM
  #557
Jondon51
Looks like I might have found the problem with my glider...I put about 30 percent of expo in the rudder mix. That may be the problem after all . Soon see next week when I fly it again.
Jondon51 is offline
Old 08-09-2019, 11:30 PM
  #558
Hope that fixes it. Good luck on the next flight.
Murocflyer
11-04-2012 11:35 AM
aeroknot
10-23-2012 01:59 AM
Murocflyer
10-01-2012 11:53 PM
Murocflyer
ParkFlyers
9
09-21-2012 02:55 AM
Unclebuck21228
10
09-19-2012 02:55 PM
Quick Reply: #35 Model Airplane Building Clinic >> DJAerotech Chrysalis 2m Electric Sailplane
Page generated in 0.07380 seconds with 12 queries
