Brushless Motor Construction Discuss design and construction of custom Brushless motors
Soldering motor leads
Old 06-07-2012, 04:19 PM
mofosheee
Default Soldering motor leads
I encountered difficulties when attempting to solder the shortened leads between the motor and ESC. Specifically, the solder would not bond to the shortened motor leads.
I believe that this is due to a coating that exists on the motor leads.
Can somebody suggest an effective method of removing this coating or applying solder?
Thanks all
mofosheee is offline
Old 06-07-2012, 04:51 PM
flydiver
flydiver's Avatar
If the wire is kinda stiff, that means they've extended the winding wire out. It is coated with a pretty tough insulation. Physically scrape it off with an exacto blade. Then flux + solder should stick.
FWIW that kind of wire is more subject to breaking by flex if it is worked at all. Depending on your application it may be more worthwhile to shorten the leads and solder flexible silicone wire to them, then the bullets.
flydiver is offline
Old 06-07-2012, 11:05 PM
Bub Steve
Bub Steve's Avatar
Take a aspirin pill( Not Bayer kind) and put it down on soldering table ,, put the wire on top and then your iron on that, hold until aspirin starts to boil for a 3-5 sec's, clean with 90+ Rubbing alcohol , solder as usual,, bubsteve
Bub Steve is offline
Old 06-07-2012, 11:22 PM
ron_van_sommeren
homo ludens modelisticus
ron_van_sommeren's Avatar
Aspirin® = Bayer AG Steve.
A brand name that became a generic name.
Any acetylsalicylic acid based painkiller will do the trick. Not ibuprofen, paracetemol etc.
Vriendelijke groeten Ron
diy motor tipsDrive Calculator
diy motor groupCumulus MFC
• Get a life ... get a 3$ Wattmeter
ron_van_sommeren is offline
Old 06-08-2012, 05:44 PM
Bub Steve
Bub Steve's Avatar
• diy motor tips • Drive Calculator •
• diy motor group • Cumulus MFC •
• Get a life ... get a 3$ Wattmeter •
I think it was you who told me years ago about this,, Been a long time since I've heard from you,, Knowing your still around has made my Day,,, I've noticed the Bayer has a different make-up that makes it dissolve faster in water and "coats" a tad of slime after that takes a min more to clean,,no biggie though, Thanks again my Bub for you always insightful comments bubsteve
Old 06-08-2012, 06:03 PM
Thanks all
Hello again!!!
Before retiring the shop used commercial hand held devices designed to remove the varnish coating from magnet wire. Problem was, these things were way over $500 each. New units can cost $1500.
Removing varnish from magnet wire is not easy, even with an exacto knife blade. (Done it many many times) Problem with the exacto knife removal process is the very high risk of nicking the soft copper wire strands. Those nicks result in point of failure if the wire is flexed back and forth a little bit.
One of these days must try that asprin pill method.
There are also chemical magnet wire varnish removers available. However they are not cheap:
http://www.youtube.com/watch?v=e1NtxCFOdFs
http://www.youtube.com/watch?v=y0CnP...feature=relmfu
Guess the bottom line is, to NEVER cut those multistrand varnish coated copper wire leads from the brushless motors we use, unless you have access to commerical wire stripping equipment.
(Before retiring, the shop bought magnet wire in all sizes from #36 to 4/0. Some of those rolls weighed in at over 400 pounds. And, a lot of heavy gauge flat sheet copper also. Those "End of spool" sources of magnet wire were sure handy for home projects.)
Old 06-08-2012, 06:55 PM
That's the best advice.. DON'T DO IT!
Guess it's a bit late if you have cut the wires but you might have to scrap the motor and put it down to experience. Try the Asprin method by all means though.. lets know if it works.
Old 06-08-2012, 07:23 PM
CNY_Dave
Jeez, don't these motor companies just use the wire where the coating turns into flux?
Anyway, I tend to hit the wire with a lighter or heat gun then gently sand with 500 grit.
Not sure if there is room with what's left sticking out, though.
CNY_Dave is offline
Old 06-08-2012, 09:00 PM
That's ok for thick single strand wire (or maybe up to 4 strands or so) but for the very fine filament multi strand windings on most factory wound motors I've never had much luck. Even if you think you have a good joint there are likely to be some of the stands not soldered and so not carrying any current.
Old 06-08-2012, 09:17 PM
CNY_Dave
How about lasers?
http://www.microjoining.com/Publishe...plications.pdf
CNY_Dave is offline
Old 06-08-2012, 09:26 PM
CNY_Dave
Looks like they even use wire and fiberglass rotating brushes, too.
Dave
CNY_Dave is offline
Old 06-09-2012, 03:29 AM
Those varnish coatings that can be soldered may not work very well in electric motor windings. Would hate to see the motor run a little bit to hot, and have all the varnish of the windings melt away
Before retiring, we used "Double Formvar" varnish coated magnet wire. This wire is rated for pretty high temperatures. That stuff was really hard to get off the copper wire. About all that worked very well was those commercial duty $1500 wire strippers.
Old 06-09-2012, 09:54 AM
I think that is the coating that we get today on the better quality magnet wire. The stuff I have definitely says something about being double coated; probably explains why it's such a pain to remove.
Old 06-18-2012, 07:26 PM
ron_van_sommeren
... One of these days must try that asprin pill method. ...
Nasty acrid fumes Deny
I've also read about people using a rotating wire brush in a Dremel to remove the varnish.
Old 06-18-2012, 08:25 PM
mofosheee
Looks like I'm screwed. When acetone did not work I knew something was up.
Old 06-19-2012, 02:15 AM
Yup, that's why I've got a powerful exhaust fan that sucks up all the fumes, and blows them outside of the house. After working with a soldering iron near 50 years, got allergic to soldering fumes.
I've tried that tiny wire brush in a dremel to remove insulation. It works fairly OK, but with the multistrand magnet wire in the Hacker and similar motors, its difficult to do a real good job on all of the strands.
Batteries & Chargers
18
05-16-2014 04:51 AM
sql_yoda
07-20-2012 05:32 AM
2006040
14
10-08-2011 05:06 PM
TylerJCooper
35
03-27-2011 08:03 PM
01-08-2011 04:44 AM
Quick Reply: Soldering motor leads
Page generated in 0.09623 seconds with 14 queries
