GWS E-Starter gets new life (pics)
Old 01-12-2007, 01:33 AM
david1234
david1234's Avatar
Default GWS E-Starter gets new life (pics)
This is my most often flown plane, with a new paint job it almost looks new. Out of my over 25 planes it is the most forgiving, and pretty darn fun to fly. Vertical performance is very impressive for a trainer.
Setup:
Motor E-flight Park 400 outrunner
Prop APC 9X7.5
Battery TP 1320 3s
AUW 15.3oz
Name:	planes 068 (Medium).jpg
ID:	21703   Click image for larger version
Name:	planes 067 (Medium).jpg
david1234 is offline
Old 01-12-2007, 01:36 AM
Rugar
FAA# OUTLAW!
Rugar's Avatar
Looks nice!
Rugar is offline
Old 01-12-2007, 04:01 AM
gsk11740
I'm outta here!
Now put some skies on that thing and you can really have fun! Nice looking plane!
I almost bought the E-Starter (and I'm still thinking about it) but I misread a review about them and something about it being three channels and went with the Soareasy instead. I now know the E-Starter can be built as a 3 or 4 channel and I also found out the Soareasy is balsa (one good crash and it's finished). Oh well, live and learn.
gsk11740 is offline
Old 01-12-2007, 04:07 AM
Hey David nice looking E! I bet she's a hoot with that 400 outrunner in it! I run an Ultrafly b series outrunner in mine, smaller that the 400 but even on a 2s she'll do wahtever I want her to!
Nice paint scheme!
Old 01-12-2007, 05:00 AM
david1234
david1234's Avatar
Thank you!! Yes, That would be very fun to have it snow equipped. The e-starter is a great aileron trainer, that when properly equipped, and lightened will be a very fun sport plane. Mine has been crashed many times (I am a new pilot), but I just did the spackling, and repaint and gave it new life. I would guess that is has well over 100 landings, and more than 25 hours in the air and still looks new. david
Old 01-12-2007, 05:03 AM
david1234
david1234's Avatar
Nice paint scheme!
Thank you Bill, It is a very fun airplane, My favorite... Yes, the 400 will definatly push it to limits Mr Lin never dreamed of. david
david1234
david1234's Avatar
Originally Posted by Rugar View Post
Looks nice!
Thank you!!
Old 01-13-2007, 01:02 AM
Kosh
Kosh's Avatar
Dave's plane flies great and I got a few pics yesterday of it in action. The extra long servo arm for the ailerons makes all the difference in roll rates.
Still slows down very nicely for a small park yet can go vertical at the drop of a hat.
ID:	21779   Click image for larger version
ID:	21780   Click image for larger version
Kosh is offline
Old 01-13-2007, 01:07 AM
david1234
david1234's Avatar
Thank you for posting those...
Old 01-13-2007, 05:22 AM
Bub Steve
Bub Steve's Avatar
Default Great look'in E-starter
Great look'in E-starter, I just put the same power-batt, combo on mine, WHAT A HOOT!!!! your bub, steve
ID:	21794   Click image for larger version
ID:	21795   Click image for larger version
Bub Steve is offline
Old 01-13-2007, 05:26 AM
EAT MORE CHIKEN! I love that paint scheme Steve. You could probably do an add for Chick-fil-a with that one!
Old 01-13-2007, 05:33 AM
Kosh
Kosh's Avatar
Got Milk? :p
Kosh is offline
Old 01-13-2007, 05:35 AM
david1234
david1234's Avatar
That looks really cool!!! Nice work!!
Old 01-13-2007, 05:37 AM
Bub Steve
Bub Steve's Avatar
Default the old bovine
firemanbill::: every time I have a boo boo or dumb-thumb a tree, I just add a spot on the old bovine about the affected area an Whaa-laa, she's ready to chew some cudd again!! your bub, steve
ID:	21797   Click image for larger version
Old 01-13-2007, 05:45 AM
heck if I did that mine would be all black!
Old 01-15-2007, 02:59 PM
ssketer4
Nice looking plane! I'm working on one right now. Does any one know what the CG measurement is on this model? The instructions do not give this measurment!
ssketer4 is offline
Old 01-15-2007, 04:52 PM
david1234
david1234's Avatar
Honestly, I have never checked mine. I will put it on the balance stand today and tell you where mine is. david
Old 01-15-2007, 09:52 PM
trewheeler
Wind Barrier Breaker
trewheeler's Avatar
Default E-Starter CG
The CG "marker" is located underneath the main wing - look for a circle that has been split into quarters moulded into the foam - they did that so you can just feel it.
Mine does the vertical thing with an el-cheapo 2409-18T ($16 eBay "Headsup rc store") and a 30amp Tower Pro ESC with a 1300mah lipo. Lots of fun, actually too much fun. I need to slow it down a bit as it is silly fast right now.
TW
ID:	22009   Click image for larger version
trewheeler is offline
Old 01-15-2007, 09:54 PM
sdculp
On the underneath side of the wing are two small circles with X's in them (not the mold release circles). These are the CG. Mine was a bit twitchy so I made it an eights of an inch or so more nose heavy.
Goes like a scalded cat with a Himax 2808-0980 and a Thunder Power 1320-3SJPL. At that power level it needs a bit of down-thrust.
Stu Culp
sdculp is offline
Old 01-15-2007, 10:15 PM
chrishwegner
Default E-starter CG
Look on page 13 of the instructions at the top shows the location of the CG.
chrishwegner is offline
Old 01-16-2007, 12:14 AM
Bub Steve
Bub Steve's Avatar
Default 1/4' behind the wing spar is dead on
sseter4::::1/4' behind the wing spar is dead on, ALLWAYS GO NOSE HEAVY WHEN YOUR NOT SURE!!!!!!!!!!!!!!!!your bub.steve
ID:	22019   Click image for larger version
ID:	22020   Click image for larger version
Old 01-16-2007, 04:16 AM
ssketer4
TW, Stu, Thanks for the info, went to check it out, and there they were!
I can figure my dimensions from there. I'll be sure to run it noseheavy at first, then go from there! Thanks to all that replied!
ssketer4 is offline
Old 01-16-2007, 06:04 PM
RacerPaul
No doors or fenders!
RacerPaul's Avatar
Where can I see videos of the e-starter on floats? Are those GWS floats?
Paul
RacerPaul is offline
Old 01-16-2007, 08:49 PM
Bub Steve
Bub Steve's Avatar
racerpaul:::yes they are, they change from land to float in about 30 sec's flat!! the floatplane part of this forum has some e-starer vids on the wet-stuff, you bub steve
ID:	22090   Click image for larger version
ID:	22091   Click image for larger version
Old 01-17-2007, 03:49 AM
Kosh
Kosh's Avatar
Guess I better throw in a few pics also. The red one has a straight wing and tricycle gear and the yellow is pretty much stock. Both run brushless gear and 3 cells.
ID:	22120   Click image for larger version
Kosh is offline
Quick Reply: GWS E-Starter gets new life (pics)
Page generated in 0.16855 seconds with 33 queries
