Help MCX controls reversed!?! **SOLVED**
Old 01-14-2009, 09:35 PM
VenomousSVT
Default Help MCX controls reversed!?! **SOLVED**
Just bought my BNF Mcx at the LHS and got it connected to me cx2 radio. I took off for some flight and immediately noticed my yaw controls and all my right stick controls are reversed! When i hit up on my right stick the heli goes backwards, whhen i hit down it goes forwards. Also with the left stick when I trun te nose it goes the opposite way of whatever I push. I have bound it to my radio several times making sure it wasnt just a glitch but have had no luck.. any help is greatly appreciated!
VenomousSVT is offline
Old 01-14-2009, 09:53 PM
powerlines
I AM NO SHOES!!!
powerlines's Avatar
There should be chanel reverse under the TX or in the battery compartment.. IF not.. That will not work with the MCX..
powerlines is offline
Old 01-14-2009, 10:29 PM
VenomousSVT
thanks for the response you were right, however my case is still a little weird.. i called eflite and they told me to flip every switch but 1 and 8 so i did. when i tried it it wouldnt fly at all. So I went back to the way it was and they all worked correctly except YAW (left stick turn). So I flipped each switch one at a time until I found that pin 8 was YAW on my transmitter. Now all is good and I am happy! thanks for your reply powerlines, hopefully this can be in the search for anyone else that has a similar problem!
blazing_angels
Warbird Electrics
06-28-2008 05:33 PM
PP Flyer
02-03-2008 05:53 PM
pilotwi
E-Flite Helicopters
08-13-2007 10:38 PM
Fuzzy
08-01-2007 04:31 PM
Phil Wiseman
Beginners - Helis
01-11-2007 11:04 PM
Quick Reply: Help MCX controls reversed!?! **SOLVED**
Page generated in 0.09150 seconds with 11 queries
