How to secure the wing spar?
Old 10-12-2008, 04:27 PM
Lieutenant Loughead
UNCLUB OWNER
Lieutenant Loughead's Avatar
Default How to secure the wing spar?
Will "Foam Safe CA" be rigid enough to secure the wing spar to a flat foamie?
In the past, I've always used Epoxy, Gorilla Glue, or Cold Temp Hot Glue... :o
Old 10-12-2008, 04:41 PM
Angler-Hi
Angler-Hi's Avatar
Hey Guy, I always used foam safe CA if the wingspar isn't embedded that deep into the wing. I would use sand paper to get the surface a semi rough and run CA into the groove and then install the spar. CA holds pretty darn good for me.
How are you installing the spar and what is it...CF...skewer?
Angler-Hi is offline
Old 10-12-2008, 05:58 PM
Lloyd
Lloyd's Avatar
Default CA on foamy wing spar
I am using it, but be careful with ZipKicker because it will melt some foams. Spray lightly and quickly wipe up any excess with a paper towel.
Lloyd is offline
Old 10-12-2008, 06:48 PM
Sky Sharkster
Sky Sharkster's Avatar
Default More Space?
Hi Lt.,
The CA will work, another trick I use is to cut up (with scissors) leftover fiberglass cloth and mix it with either Ca or epoxy and make a slurry or goop to fill in the space around the doubler. Microballons will work also, but they don't seem to add as much strength as the 'glass cloth fibers.
Ron
Sky Sharkster is offline
Old 10-12-2008, 08:22 PM
fr4nk1yn
^_^
fr4nk1yn's Avatar
I hope CA will work 'cause I just built one, yet to maiden that's held in place with only CA. A 5/16" square spar in bluefoam.
fr4nk1yn is offline
Old 10-12-2008, 09:01 PM
groundrushesup
groundrushesup's Avatar
I found a neat trick with spars in cut-out recesses like this - I almost completely coat the spar in gorilla glue, insert it into the recess, wipe off the excess with a spirits-soaked rag, and then cover the recess with 3M Transpore. The result after curing is that the excess GG foams through the pores in the tape and leaves almost a perfectly smooth surface - ie, the excess ends up on the outside of the tape and can be peeled off with ease. I realize that Transpore is not the cheapest stuff around, but I have a surplus of it from a motorcycle 'incident' a few years back lol.
I learned this completely by accident one day, and I think I have a few pictures of how it worked on my RCSuperPowers Extra 300.
cheers
groundrushesup is offline
Old 10-13-2008, 01:26 AM
Lieutenant Loughead
UNCLUB OWNER
Yeah, the wing spar is a Carbon Fiber tube, and it's recessed into the 6mm Depron wing.
Normally I would use Gorilla glue, but I want to try to make this one as light as possible.
Old 10-13-2008, 03:54 AM
Angler-Hi
Angler-Hi's Avatar
Yeah, I would use the foam safe CA. That's what I'm building my GWS ME-109 with and so far so good. I also used spars on my Cessna 206T and it worked great! Good luck Guy, let us know how it turns out.
Old 10-13-2008, 03:57 AM
gfdengine204
gfdengine204's Avatar
Yanno, I have heard that carbon fiber arrow shafts from Walmart work just as well, and cost less. (I got mine for less than $5/shaft)
gfdengine204 is offline
Old 10-13-2008, 04:01 AM
fr4nk1yn
^_^
fr4nk1yn's Avatar
Gorilla Glue might not be as light as CA but if it could be used I would over CA is a "questionable" area.
It's still very light compared to say epoxy.
Posted via Mobile Device
fr4nk1yn is offline
Old 10-13-2008, 06:16 AM
Hi Lloyd try this Homemade Kicker, it works great and wont hurt the foam, mix 1 teaspoon of baking soda, to 1 oz of water, shake well, and use a spray bottle to apply, No Fumes from a Kicker and safe to use, just wipe off the excess after your done, or it will leave a baking soda power film, thats all that I use now days, and the guys in my club love it, and its Cheap, Like Me hope that helps, Chellie
Old 10-13-2008, 02:49 PM
Lieutenant Loughead
UNCLUB OWNER
Kev -- you haven't been shopping at www.KarglUSA.com -- I can sell you a Carbon Fiber Tube (hollow) 4x3x750mm (Wing Spar) for $3.11.
Okay -- maybe I haven't posted that on my web site just yet... I have too many products, and too little time!
I gotta say, I'm really happy that my prices are lower than WalMart!
Old 10-13-2008, 03:26 PM
Angler-Hi
Angler-Hi's Avatar
Guy, I didn't know you had an online store!! That's awesome man. I just added it to my favorites folder! I remember you talking about it a while back, but didn't know it was up and running. That's sweet man! I know where I'll be buying my next warbird foamie!!
Old 10-13-2008, 04:37 PM
Lieutenant Loughead
UNCLUB OWNER
LOL -- thanks Mike. I know this is off topic, and I hope I don't get in trouble with the mods, but I'm opening an account with GWS. I hope to offer GWS airplanes and GWS props on my web site by the end of the month!
Old 10-13-2008, 04:49 PM
gfdengine204
What would shipping run me? And don't say a pizza, either!
Old 10-13-2008, 10:24 PM
Angler-Hi
Angler-Hi's Avatar
Sorry man, didn't mean to get off-topic there. Looks like I have a list of GWS birds to make...good luck with your CF spar and CA
Old 10-16-2008, 12:54 AM
cyclops2
Default Deep enough?
I use a scrap piece of hand made plywood. Made from 2 precut pieces of wood veneer scraps glued together & lightened with some holes.
I then LIGHTLY coat the spar with Tightbond II & insert it in & out a couple of times. These are snug fits. 2 weeks later it has set up for any flights.
cyclops2 is offline
Old 10-16-2008, 02:54 AM
fr4nk1yn
^_^
fr4nk1yn's Avatar
Two weeks?! O:
fr4nk1yn is offline
Old 10-16-2008, 04:21 AM
cyclops2
Default At my age ?
No rush with 6 planes & 6 hydros to build & play with.
Name:	shovel nose hydros..gif
cyclops2 is offline
glider7
Combat
01-29-2009 01:12 PM
Nitro Blast
07-18-2008 09:16 PM
jas904
07-03-2008 11:22 PM
JGMM_BC
07-02-2008 08:57 PM
jasmine2501
04-22-2008 06:12 AM
Quick Reply: How to secure the wing spar?
Page generated in 0.13393 seconds with 16 queries
