Top Flite Monokote - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Top Flite Monokote
Old 03-01-2018, 11:48 PM
garyp1029
Default Top Flite Monokote
I have read that a few years ago there was a problem of getting Monokote to shrink. Anyone know if that is still a problem? Thanks.
garyp1029 is offline
Old 03-01-2018, 11:53 PM
I just recently covered my 1/5 scale Waco with Monokote with no issues. I do like Ultracote better but couldn't get it in the color I wanted for the Waco
Old 03-02-2018, 12:55 AM
A few of us have been using the film from ValueHobby. You can not beat the price. Shrinks what seems to be a mile. Sticks as well as Ultracote. One guy swears it is identical to ultracote but I think it is a little bit stiffer. The stuff from Hobbyking "aint bad",butI will continue to use the stuff from ValueHobby.
In my experience, the current version of Monocote seems to require quite a bit more heat.
Old 03-02-2018, 06:03 AM
Past President of PSSF
Monokote has always been a high heat material, I use it on tough strong airframes because it will pull hard, a glider wing might crush.
I have never had a time where it did not shrink.
Some materials may shrink or stretch more or less than others, but that's why we have different types. Compound curves will test your ability, I find the hot air blowers used for making greeting card to be very helpful. Mine has an outlet about 1/2" dia, you can really get into tight spots.
Wildflyer is offline
Old 03-02-2018, 12:36 PM
I used a domestic iron for years .. great for flats but always had those awkward spots. Then I bought the Solarfilm Iron ... then I realised what I had been missing.
I also had a Hot Air gun designed for film use instead of the too low temp Hairdryer or too hot Paint Stripper versions
Of course that was many years ago and I lost them ..
Scroll fwd many years and I bought the Hobby King Iron and their 'pizza cutter' .... magic. All I need now is another Hot Air gun for film.
I use nearly always HK film now as Solarfilm - my preferred is too expensive ...
HK film - I like but its heavier than Solarfilm and has that white adhesive back that 'creeps' leaving a joint line. Why they cannot have clear like others ?
Old 03-02-2018, 03:33 PM
I mainly use the Hobby King film and just wipe the joint with some acetone quickly to remove the glue line but I don't really have a problem with it. I have a iron with a digital display and I write down the temps for each different film I use. 5 degrees can make quite a difference sometimes. I got the digital iron for less than what some were charging for the iron with the adjustable knob.
Old 03-02-2018, 04:11 PM
Once again this hobby shows the variations that make it so great. So many different methods, brands, and ways of making it all work. I learn something just about every time I read one of these threads.
And all done without smashing other products. Great input guys.
Tarasdad
WWI Era
22
10-14-2013 08:04 AM
Scale E-Powered Aircraft
27
02-27-2012 03:38 AM
ScottVan
Warbird Electrics
12-03-2011 07:24 PM
rk212
Warbird Electrics
10-09-2011 02:40 AM
FlyingMonkey
Off Topic Chit Chat
66
04-04-2011 05:58 AM
Quick Reply: Top Flite Monokote
Page generated in 0.06679 seconds with 12 queries
