ESC problems HELP - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Brushless Motor Construction Discuss design and construction of custom Brushless motors
ESC problems HELP
Old 08-26-2010, 03:38 AM
alcarafa
MONTEsorry Rc Club México
Default ESC problems HELP
I have a turnigy plush 30 amp ESC every time I connect it makes normal procedure beeps, after that it keeps with intermitent beeps and does not recognize number of cells (e.g. 3 cell lipos = 3 beeps) in last step before arming the engine.
I removed the shrink tube and look at the circuit, there is nothing burned you can see, also checked the wires to be ok.
It used to work ok, not anymore.
What could the problem be, Is there a way to fix it
alcarafa is offline
Old 08-26-2010, 04:11 AM
check the throttle trim,it may be to high and not allowing the arming sequnce to finnish. turnigy plush are great esc's and are all i really use except for a few cheapo's i had before using plushes.
Old 08-26-2010, 01:13 PM
Numbthumbs
Master of Bisaster
Maybe your throttle is reversed on your TX? Any dodgy connections? All well soldered and clean fitting?
My guess is the throttle reversed, is not at neutral when you plug in the battery, trim is too high, or you have some dodgy connectcions. If the ESC was dead, you would probably not get any tones out of it.
Hope you get it sorted!
Numbthumbs is offline
Old 08-26-2010, 02:19 PM
DanWard
DanWard's Avatar
Mine did that until I taught it the throttle range. Or perhaps I should say until I programmed the throttle range. Then when I changed radios it did it again until I again calibrated the throttle range.
I'm old and may not have the details right, you know how memory can be. So check they manual as it is described well.
As I remeber you
1. turn transmitter on
2. Go to full throttle on transmitter
3. power up esc and listen for beep, beep sequence that indicates it recongnizes full throttle.
4. Then within some time limit you must go to zero throttle. It again gives a beep beep sequence saying it recognizes zero throttle.
After I do that...mine works as advertised.
I'm real new to this. I hope my input helps
DanWard is offline
Old 08-26-2010, 05:04 PM
alcarafa
Thanks guys have tried all of the above and esc still doesnt arm on cell numbers & engine in last step.
Have tried programing with turnigy card only way it stops beeps in last step is when I set it high start mode, with futaba Tx's you have to reverse throt to work right I use Spektrum.
This is a real mistery it was working all right, cant figure out what is wrong.
Any more ideas are welcome.
alcarafa is offline
Old 08-26-2010, 05:39 PM
constantCrash
prefectionist
constantCrash's Avatar
Still check to make sure you didn't accidentally reverse the throttle on your TX. this really really sounds like throttle is reversed.
constantCrash is offline
Old 08-26-2010, 06:53 PM
alcarafa
Thanks guys problem is solved , one of wires going to engine was broken inside so this made a false contact, replaced all of them just to make sure it will not fail again.
alcarafa is offline
Old 08-26-2010, 07:24 PM
darylm44
darylm44's Avatar
Try rebinding your Rx. I have had to do this a couple of times.
darylm44 is offline
Old 09-26-2010, 06:37 AM
LuciousLarry
take the esc with your transmitter to a local hobby shop or go to web sight it has to be programed to your radio.
LuciousLarry is offline
cheshireflyer
08-22-2009 02:48 PM
Reckless_Meanie
01-10-2009 03:03 AM
burncycle
01-13-2008 04:35 AM
peterkron
03-03-2007 06:01 AM
645peter
General RC E-Heli Talk
10-31-2006 09:01 PM
Quick Reply: ESC problems HELP
Page generated in 0.11373 seconds with 13 queries
