GreatPlanes You-can-do .60?
Old 08-09-2015, 07:54 PM
Angler-Hi
Angler-Hi's Avatar
Default GreatPlanes You-can-do .60?
Has anyone built this plane: http://www3.towerhobbies.com/cgi-bin...?&I=LXDUJC&P=0
All I have left to do is drill the holes for the cowl, to mount to the fuse. I know this may sound nuts...but this is the first plane I've built where I had to drill holes in the cowl for mounting, lol. Any tips for a good "alignment"? Thanks.
Angler-Hi is offline
Old 08-09-2015, 08:17 PM
Stevephoon
Stevephoon's Avatar
I have not built one. There is a guy at my club that flies the old slimmer version. It flies really well, it maybe not a true 3D plane, but loads of fun.
For mounting cowls, here's what I do.
With the cowl removed. Take a piece of tape and fold back about 1/3 of it in itself. (So there is a part that's not sticky.) Stick this on the fuse so it just reaches over the cowl mounting block. The tape should be positioned so that the cowl can slip underneath the part of the tape that is not sticky. Start a screw thru the tape and into the mounting material. Repeat for all mounting positions. Then remove the screws.
Put the cowl on then mount the base of the spinner on the motor. Line up the cowl with the spinner. Draw a dot thru the holes in the tape on the cowl with a thin sharpie (or something similar.) Remove the cowl and drill small holes on the marks. Remove tape and mount cowl!
This has worked for me on my planes anyway...
Stevephoon is offline
Old 08-10-2015, 12:32 AM
Angler-Hi
Angler-Hi's Avatar
For mountain cowls, here's what I do.
Steve, thanks!
Old 08-10-2015, 04:45 AM
swimmer
Fully assembled plane like this hanging on our local hobby shop ceiling for sale. Very nice looking airplane.
swimmer is offline
Old 08-10-2015, 06:01 AM
Not really a lot to do to assemble one. Very nice planes. They are LIGHT and thus don't handle impact well, but they are very good for intro to 3D.
with motor mounted. slide the cowl on, then a scrap 1/16 inch thick disc of balsa/ply/cardboard (same dia as spinner backplate)... then the spinner backplate (broke prop as spacer and tighten down the prop nut). Make sure the spinner goes all the way back as normal (the scrap disc should NOT touch the prop hub... drill that hole oversize a lot)
Now you can pull the cowl tight against the disc and spinner backplate and automatically get the right spacing and you can see how the cowl will line up to the spinner.
Then using the above method for hole locations... perfect every time.
Old 08-11-2015, 12:50 AM
Angler-Hi
Angler-Hi's Avatar
I appreciate it man.
70sflyer
Warbird Electrics
04-17-2014 07:09 AM
motor12
Warbird Electrics
12
01-03-2014 06:55 AM
3D Flying
06-17-2013 06:02 AM
cpmalish
11-04-2011 03:32 AM
constantCrash
02-15-2011 04:47 PM
Quick Reply: GreatPlanes You-can-do .60?
Page generated in 0.08697 seconds with 13 queries
