Covering material
Old 12-12-2020, 02:49 PM
superdave62
Default Covering material
What covering material do you like to work with? I've only used TopFlte Monocote. Pros and cons of other materials would be appreciated.
superdave62 is offline
Old 12-12-2020, 10:44 PM
I have been using exclusivly Hobby King film. It is one of the best and stays tight. I have several planes years old and it is still tight as a drum, however the purple on one gliders wings has faded a bit but still looks good. I really think it is the best value film.
Old 12-13-2020, 03:36 PM
I like ultracote, especially the park lite stuff for gliders.. I use Monokote as well.
The biggest differences I encounter is that ultracote seems to be easier for me to work around corners and such, however it does not hold up well to glow fuel if you are flying that as well. It works great on electrics though. UC does seem to wrinkle a bit and require some reheating form time to time to get it tight, more so that I find with MK.
Old 12-23-2020, 04:07 PM
yorcram
yorcram's Avatar
i like solartex, but my stash has run dry, not sure what I will replace that with
yorcram is offline
Old 08-25-2021, 12:04 AM
The Professor
Professional Nerd
The Professor's Avatar
Default I use easycoat
Ha, that title sounds like I know what I am talking about.
I have just made and covered my first plane. So I looked for something cheap enough for me to make mistakes with. The model shop sell rolls of seconds, so I can buy 10mtrs for less than 2mtrs of either perfect material or other brands.
It seemed quite nice once I got the temperature right. The flaws are not material flaws, but colour patching, as I painted the model, this was not a concern.
It took a while to get the shrink temp right, and my next plane will use the same covering.athough I want to create a fabric effect of the next one to match the vintage of the plane.... Will see how that goes. I shall return and post pictures of that.
The Professor is offline
Old 08-25-2021, 03:48 PM
I have used a variety of coverings over wood and foam. They all work. I have used Monocote and Ultracote more than the others but can't say I have a favorite.
Old 10-05-2021, 11:58 PM
E-Challenged
E-Challenged's Avatar
Ultracote Parklite, for small electric powered models. Does not curl back and stick to itself while separating from backing, easier to separate from backing than other "lite" coverings.
E-Challenged is offline
Old 10-06-2021, 01:39 PM
With the demise of Solarfilm - that means Solartex is no longer ..... one of the best 'fabric' style for WW1 etc.
Looks like I'll be going back to 'nylon + dope' for wood jobs ... 'nylon + pva' for others.
skyler
12
11-09-2021 09:36 AM
jensheydel
WWI Era
21
04-19-2018 02:22 PM
pd1
106
08-24-2014 05:00 PM
E-Challenged
08-30-2012 01:27 PM
DanWard
12-12-2010 07:49 PM
Quick Reply: Covering material
Page generated in 0.08454 seconds with 11 queries
