Biplane from Dollar Tree Foam? - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 08-02-2019, 05:53 PM
trying2fly
Question Biplane from Dollar Tree Foam?
Are there any build pictures, plans, etc for building a biplane out of Dollar Tree foam? I have thought about making a biplane out of the "NOOB" from Experimental Airlines but I need plans for measurements and the like. Does anyone have plans for a simple foam biplane? Thanx so much!!
trying2fly is offline
Old 08-02-2019, 10:52 PM
Abuelo
Abuelo's Avatar
Take a look at Flite Test. Their early plans were for Dollar Tree foam but now sell their own brand.
The Baby Blender has been popular for quite some time. https://store.flitetest.com/flite-te...t-1003/p673667
Another option is Outerzone.com. Their plans are not for foam board but you could use the outlines, incidences, etc, as starting points for your own design. The Dakota might be a good starting point as it is a cabin job with sheet based wings. https://outerzone.co.uk/plan_details.asp?ID=7191
Good luck, and keep us posted on your
Abuelo is offline
Old 08-03-2019, 02:30 AM
trying2fly
Thank you so much
Old 08-03-2019, 09:42 AM
Here's a few ...
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old 08-03-2019, 09:57 AM
and more ...
Its actually not hard to take a 3 view or a standard full form plan and convert to a flat foam sheet model. All you need are the outline dimensions and then carefully add tabs to any that need separating and then later joined : ie fuselage sides.
There are hundreds of plans online to download free ... just a simple Google "Free foam biplane model plans" for example ...
File Type: pdf
Old 08-03-2019, 06:44 PM
trying2fly
and more ...
Thank you so very much for your input....you are always loaded with wonderful advice...!!!!!!!!! The links were great!!!
bigoledude
04-28-2019 11:14 PM
Mojo
09-18-2017 02:33 AM
40
08-30-2015 01:38 AM
Wrongway-Feldman
19
05-14-2014 09:00 AM
02-21-2013 03:58 AM
Quick Reply: Biplane from Dollar Tree Foam?
Page generated in 0.05759 seconds with 23 queries
