Sebart Katana 30 - a bit overweight!!!!!!
Old 02-10-2009, 02:41 AM
Rick Rotorhead
Default Sebart Katana 30 - a bit overweight!!!!!!
Just out of interest I weighed the component parts of my finished (yet to fly) Katana s30e.
The spec says the stock weight with a 3s 2100 pack is just 1200g.
Mine has a 4s 2100 pack - that adds around 30g, yet to AUW is 1387g. That's a good 15% overweight !
I'm sure that even 1/2 a bottle of Zap CA doesn't weigh 150g and I'm using a Spektrum AR6200 Rx which is pretty light too - so I wonder where Sebart get their low weight from.
Oh well, its not a show stopper, I'm sure it will still fly great at 1387g.
On a positve note, both wings weighed the same to within less than 1g
Just need some good weather now
Rick Rotorhead is offline
Old 02-10-2009, 04:49 AM
phupper
Flyin' Phup
phupper's Avatar
I suspect that extra cell weighs more than 30g, mine do. What did you cover with?
Phil
phupper is offline
Old 02-10-2009, 06:34 AM
1 387 gram = 48.924 985 224 ounce
http://www.rcgroups.com/forums/shoread.php?t=623855
your fine on the weight, only about 1.924Oz or 54.5 grams and that may well be the extra Cell your using
Available in
Red/Green/White
and
Red/Blue/White
As pictured.Length:49.2"Wingspan:49.2"Wing Area:566 sq. in.Weight:47 oz. as flownWing Loading:~10 oz/sq. ft.Servos:HS-65's or equivalentTransmitter:Futaba 9C / 14ZReceiver:Futaba R146iP PCMBattery:FlightPower Evo 20 25C 2170mAhMotor:Hacker A30-14LESC:Hacker X40Manufacturer:SEBART di Sebastiano SilvestriAvailable From:Fedon Aircraft
Old 02-10-2009, 06:37 AM
47 ounce = 1 332.427 586 9 gram
Old 02-10-2009, 08:02 AM
Alpea42
Parkjets Rule 3D Rocks
Alpea42's Avatar
Dang the 49" one looks alot like the E-Flight Minni-Funtana X.
Alpea42 is offline
Old 02-11-2009, 01:06 AM
Rick Rotorhead
Ok, thanks guys, so 48 Oz is ball park ok for this aircraft then. I was going by the weight quoted on the kit box, which said 1200g.
noiying
Scale E-Powered Aircraft
8
11-15-2007 08:25 PM
MDS007
10-16-2007 06:47 PM
Mike Parsons
3D Flying
06-27-2007 03:24 PM
snakeman
3D Flying
02-06-2007 02:05 AM
atlav8r
New Product Announcements
01-30-2007 03:24 AM
Quick Reply: Sebart Katana 30 - a bit overweight!!!!!!
Page generated in 0.08146 seconds with 12 queries
