Balancing a 30mm true turn spinner - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 07-08-2012, 02:37 AM
mofosheee
Default Balancing a 30mm true turn spinner
Does a quality tutorial exist for balancing a small electric True Turn spinner that is intended to be used on a 30K plus motor? Thanks all
mofosheee is offline
Old 07-18-2012, 01:37 AM
Bill G
Super Contrubutor
Bill G's Avatar
No substitute for good ol' trial and error with weights. It is amazing how out of balance some spinners are, especially being the expensive ones that one would think are balanced. I've spent hours balancing spinners. You could set it up on a prop balancer, but there is no easy way to indicate if the weight should be added at the base, or toward the tip. With longer cones, find the spot/weight that smoothens the spinner, and then see if it will further smoothen by moving the weight outward and adding/removing weight.
One thing that is often overlooked is the relation of the motor internals to the prop/spinner, when it comes to balancing. I've managed to perfectly smoothen out props and fans by simply rotating the prop/spinner or fan/adapter in small increments, until you find the sweet spot.
Bill G is offline
Old 07-18-2012, 03:11 PM
mofosheee
I have gain an appreciation for how tedious balancing can be. Thank you
Old 07-19-2012, 09:22 AM
Larry3215
Look out for that tree!!!
Larry3215's Avatar
Trueturn spinners are factory balanced - and they really do it.
No need for you to spend time on when you could be flying
Larry3215 is offline
Rolling Thunder
Informal Clubs
2931
07-30-2017 06:27 AM
Quick Reply: Balancing a 30mm true turn spinner
Page generated in 0.06235 seconds with 14 queries
