Lipo Cell Balancer
Old 06-05-2008, 02:47 PM
edran
EDRAN
Default Lipo Cell Balancer
I have a Triton 2 charger and Equinox balancer.
Do I need to use my balancer on every charge or can I charge direct
and use the balancer say once a week or every so many times of use?
Thanks Edran
edran is offline
Old 06-05-2008, 02:51 PM
Heli Jim
Grandpa, Golfer, Pilot
Heli Jim's Avatar
You can do it either way but using the balancer is a good idea. A lot
of people use chargers that balance the pack every time. You won't hurt
the battery by balancing it, so more often is better than less.
If it were me, I'd do it every time.
Heli Jim is offline
Old 06-05-2008, 03:13 PM
edran
EDRAN
Default Thank you
Thanks Jim for the fast reply. I will take your advise.
EDRAN
edran is offline
Old 06-06-2008, 06:30 AM
Larry3215
Look out for that tree!!!
Larry3215's Avatar
The other major reason to use a balancer every time is safty. Your far less likely to burn your house down
Good in-line balancers will stop the charge if any cell in the pack goes over voltage.
Larry3215 is offline
Old 06-06-2008, 04:41 PM
edran
EDRAN
Default Good advise
Thanks Larry, I will for sure charge outside.
ED
edran is offline
Old 06-06-2008, 05:19 PM
Ohio AV8TOR
Ohio AV8TOR's Avatar
If you have it then use it. The balancer prevents any cell from charging more than 4.2v. That is a sure way for premature cell weakening.
Ohio AV8TOR is offline
Old 06-06-2008, 08:40 PM
snapperZ
I have been looking at the Triton JR as well, but this statement throws me off a bit:
The JR has output ports for charging. The Lipos typically have two connections: One for receiving the charge from a charger (such as the JR), and the other for balancing.
How would the JR be able to support in-line balancing then? The balancer connected to the Lipo would not be able to shut the charge off. Maybe I should not be looking at the JR if it doesn't provide an in-line balancer? I read a lot of comments on the charger, as well as http://www.rcgroups.com/forums/showt...81&skey=23f2d7
Any thoughts on this? Thanks.
snapperZ is offline
Old 06-06-2008, 08:43 PM
snapperZ
I suppose here is one answer to my question: http://www.electrifly.com/chargers/gpmm3160.html
But If I bought this product, I would then be locked into Electrify Lipos (Is that correct?).
snapperZ is offline
Old 06-06-2008, 09:35 PM
everydayflyer
Southern Pride
everydayflyer's Avatar
Equinox is same as Hyperion LBA6 now discontinued / replaced by LBA10.
I made apapters and used LBA6 with PolyQuest/ Hyperion, Vampower Pro,DuelSky, Thunder Power,Electri Power,E Tec and several other brands of LiPolys.
Best advice I can offer anyone is to learn how packs / balancing leads are wired,learn to solder and make whatever adapter you need to use Brand X with Brand Y as the vendors will not standarize.
The madness has been going on for well over three years.
http://www.rcgroups.com/forums/showp...0&postcount=29
Charles
everydayflyer is offline
Old 06-06-2008, 10:24 PM
snapperZ
Thanks everydayflyer,
That sounds like a great way to keep from purchasing multiple balancers. It is a little duanting to solder whatever adapter I need. (especially given the results if a mistake is made.) Perhaps I will just be better off by finally deciding to purchase a few lipos of the same brand with their associated balancer. Does that sound appropriate?
I have read through the long threads on which is best, and it seems that I can't go wrong with quite a few of the choices.
snapperZ is offline
Old 06-07-2008, 03:30 AM
everydayflyer
Southern Pride
This may help.
http://www.rcaccessory.com/pdf/Batte...on%20Guide.pdf
Charles
edran
06-05-2008 02:51 PM
03-26-2007 09:32 PM
CitaFly
03-01-2007 10:30 PM
jwr0
03-13-2006 12:30 AM
kc10boom
02-06-2006 07:47 PM
Quick Reply: Lipo Cell Balancer
Page generated in 0.11547 seconds with 13 queries
