Is anyone else using Hornet ESCs?
Old 01-18-2022, 10:12 PM
Javelin71
Default Is anyone else using Hornet ESCs?
I purchased several Hornet ESCs from a U.S. seller on eBay. I'm having a problem with trying to get the one that I've tried using into Programming mode. The instructions state to turn on the transmitter and set the throttle stick to the maximum position. Then power on the aircraft. There are supposed to be several BEEPs and then the ESC will be in the mode to allow parameters to be changed. The same thing is true if you want to calibrate the throttle stick travel - you set the throttle to maximum and then power up the plane and after a couple of BEEPs, you push the stick down and the throttle range is set. With this ESC using the above procedure results in a continuous series of rapid beep that continue until I set the throttle to the minimum position. It never seems to go into programming mode - it just detects that the throttle is not at the minimum position.
Is anyone else using these Hornet ESCs and have you had any similar issues that you've been able to solve successfully?
Thanks in advance
Javelin71 is offline
Old 01-18-2022, 11:42 PM
Have you tried moving your throttle trim up a bit to see if that gets it into program mode?
Old 01-18-2022, 11:53 PM
Javelin71
I didn't think to try that but I'll give it a go and let you know how I make out. Thanks.
Old 01-19-2022, 12:04 AM
Javelin71
I adjusted the throttle end point to 120% but that didn't make any difference. Then I also ran the trim up to maximum, but that didn't help either. I'm beginning to wonder if the ESC is defective.
markm75
05-31-2015 06:20 AM
maxflyer
05-03-2013 08:42 PM
Beemerider
Multi-Rotors
03-22-2013 01:16 PM
dhdsracer
03-13-2013 06:45 PM
BOBWRC
01-06-2011 11:39 PM
Quick Reply: Is anyone else using Hornet ESCs?
Page generated in 0.07271 seconds with 9 queries
