Load checker without using motor / ESC etc.
Old 03-15-2022, 10:35 AM
Default Load checker without using motor / ESC etc.
I am sure that I am not only LiPo user that has a lot of LiPos' and amongst the many - are odd ones that at times do not perform. I try to mark them as ?? to avoid using again ... but one or two can get used again and occasionally seem to be OK.
I have a bench set-up .... motor mounted to a flat plate I can clamp in a vice ... ESC and Servo Tester .... I can connect wattmeter and run up to observe / listenm and read results. But its a pain having to charge up the LiPo - then connect - run and then storage discharge.
I've tried using the Internal Resistance values to check - I have a dedicated IR meter as well as on the chargers ... but that has not proven to be solution.
So ? Question is - what is there out there that can be used to reliably determine a LiPo's condition without too mucxh work involved ... lets say charge up to average 4.0v per cell .. plug into XXXX ... load is imposed and you get direct result ?? I know that sounds like a Wattmeter exercise - but I'm looking for something that does not need ESC / Wattmeter / Servo Tester etc.
Any ideas Guys and Gals ??
Old 03-16-2022, 05:51 AM
Past President of PSSF
I saw someplace that if a fully charged Lipo is loaded to a point that the voltage output drops anything over 0.3 volts per cell then that is the current limit for that particular battery. Basically the C rating of that battery at that time.
The guy explained that if a 4 cell battery dropped over 1.2 volts in total then that would be the limit of current for it.
I don't know if this is all true, it seems a bit harsh to me. If it is true, then many of my batteries are over the hill.
I haven't heard of anything new other than the SkyRC BD250 Battery Discharger & Analyzer and similar devices
Wildflyer is offline
Old 03-16-2022, 08:16 AM
0.3V per cell .... blimey - that's not much ..... IMHO - thats being super kind to the battery.
Old 03-16-2022, 06:47 PM
I fully agree Nigel,
I don't know how much of an "Expert" the author is on batteries, but he made it into the book.
Old 03-16-2022, 07:15 PM
My reason for looking is that I am currently going through my huge collection of LiPo's ...
First charge up to max 4.2V per cell.
Read of Charger the Internal Resistance of each cell. I know temp makes a difference - but I'm looking for big differences not small.
I have test motor with 11x5.5 prop on board clamped in a vice. Sevo Tester control and ESC /BEC
I have found before that IR results are not as reliable as some claim ...
Example : Cells are in mOhms ... Motor test is bad * ... fair ** Good ***
LiPo # ...... Cell 1 ........ Cell 2 ......... Cell 3 ............. Motor test
#4 ..............066 ........... 021 ........... 023 ................***
#5 ............. 066 .......... 008 .......... 011 ................ **
They are same size / capacity / brand .... I would expect #5 to perfo0rm as good as or better than #4 ... but it did not. It was plainly less capable.
Old 04-05-2022, 10:54 AM
maybe this Lipo tester might help,
https://www.rcdronegood.com/best-lip...istance-meter/
Old 04-07-2022, 09:11 PM
pmullen503
On the subject of voltage drops under load.
Before I had telemetry, I set a timer so I'd land at around storage voltage. That way I could pack up batteries and go home without having to mess with them. Now, I set my telemetry alarms for 3.3V/cell. If they go off under power, it's time to land. I want to have at least 3.7V/cell resting (again, pretty much storage voltage).
The point is if my alarms are going off but I still have more than say 3.8V/cell I know that battery is getting weak and it gets "de-rated" for use in less demanding planes. So while I may get one or two years in an EDF, but the same battery can still be fine for use in prop planes for several more years.
pmullen503 is offline
Electronic Builders Workshop
9
01-07-2019 08:07 AM
Topher
23
12-11-2016 03:55 PM
Support & Suggestions
11-12-2015 10:32 PM
Romans5.8
07-02-2015 03:53 PM
GBLynden
11
09-28-2013 10:02 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Quick Reply: Load checker without using motor / ESC etc.
Page generated in 0.07619 seconds with 9 queries
