Avian ESC LVC Type ="Surge SW"
Old 03-03-2022, 05:35 PM
jevla44
Default Avian ESC LVC Type ="Surge SW"
Got a new Avian 100A ESC and the LVC type defaults to "Surge SW" with "Soft" and "Hard" as the other two options. Others found this too when upgrading to the latest firmware on older Avian ESC's. I have searched and searched and can't find any explanation of this. The soft an hard functions are easy to understand. Maybe the motor starts surging or pulsing after reaching LVC? I can't see an advantage if so. I would rather go soft and have 50% power for landing than a "surging" motor.
jevla44 is offline
Old 03-03-2022, 06:39 PM
crxmanpat's Avatar
I found nothing about this in a search. I did see a thread on RCGroups where someone asked the same question at the end of 2020. No answer was given. I would just stick with the default soft cutoff.
crxmanpat is online now
Old 03-03-2022, 08:44 PM
Past President of PSSF
I have an ESC that goes into the surge mode when the voltage drops.
I like it, all I have to do is slow down a little to reduce the power drain and the surging stops and I set up for landing.
On my other ESCs that just go hard stop, I have to drop to no throttle for a bit then I can get a little power, however, if I go a little high, I have to start over and reset. All that seems to eat up time that the surge type does not.
I will look for that type in the future.
Wildflyer is offline
11-14-2021 05:11 PM
11-02-2021 01:03 PM
05-28-2020 09:50 PM
RCFlyer44
01-07-2014 12:16 AM
FlyingBrick50
Heads UP RC discussion
11-21-2011 10:18 AM
Quick Reply: Avian ESC LVC Type ="Surge SW"
Page generated in 0.10181 seconds with 10 queries
