GT 150A Power Meter doesn't work
Old 07-09-2018, 07:28 PM
Jack_K
Jack_K's Avatar
Default GT 150A Power Meter doesn't work
I bought one of these power meters on eBay. It doesn't display any watts when I connect it between the battery and the ESC. Of course the ESC is connected to the motor. It only displays the voltage.
I have the battery connected to the source leads and the ESC to the load leads. I have even tried swapping the source and load leads with adapters, but both methods display voltage and no current.
Am I doing something wrong?
File Type: jpg
Jack_K is offline
Old 07-09-2018, 09:54 PM
You are loading it with a motor I take it? You only mention connecting a ESC, no mention of motor. An ESC won't display watts by itself.
Old 07-09-2018, 10:06 PM
Jack_K
Jack_K's Avatar
Yes, the ESC is connected to the motor.
Jack_K is offline
Old 07-10-2018, 06:00 AM
Well it sounds like you are doing it correctly. Maybe a photo of it all hooked up?
Old 07-10-2018, 12:58 PM
Maybe a stupid question.. You did actually power up and run the motor with a prop on to give some load?
Obviously if the motor was sitting idle it wouldn't draw any current thus would not record any Watts.
Old 07-10-2018, 03:55 PM
Jack_K
Jack_K's Avatar
OK. I'll elaborate.
The motor is in the airplane and has a 12x6e prop on. The motor is wired to the ESC, the ESC is connected to the power meter, and the pm is connected to the battery.
I turned the transmitter on and verified it was set for the correct plane. I THEN connected the battery to the pm. I advanced the throttle to full and the motor (and prop) spun up. I held it for about 8 seconds, throttled to idle, and back to full throttle. The pm had only displayed voltage the entire time.
Then I made some adapters and tried it with reversed connections and it did the same thing.
I hope that is clear enough for everyone.
Respectfully,
Jack
Jack_K is offline
Old 07-10-2018, 08:50 PM
Thanks for confirming, it sounds like a faulty watt meter as it’s not reading Amps
Brushless Motor Construction
48
03-19-2019 12:08 PM
06-28-2017 04:22 PM
01-09-2017 02:23 AM
Batteries & Chargers
02-15-2011 02:02 PM
Off Topic Chit Chat
33
01-27-2011 01:50 PM
Quick Reply: GT 150A Power Meter doesn't work
Page generated in 0.07112 seconds with 11 queries
