What LiPo for TwinStar II?
Old 07-16-2006, 06:15 AM
Virgil Kee
Default What LiPo for TwinStar II?
Anyone have experience with LiPo's in the TwinStar II? I plan to use the stock motors (Multiplex 6V 400's, 8A max. current ea.). I'm stumped, since the Tower Hobby Tech Notes state that the model weighs 3.3 lbs! (53 oz.) Does this presume a Ni-MH batt. pack? Let me hear from the real world!
Recommendation?
Virg.
Virgil Kee is offline
Old 07-16-2006, 06:53 AM
jdetray
Hi Virg-
The Tower Hobby "Notes From Our Tech Department" for the Twin Star II says:
Battery: 7 or 8-cell flat
That certainly isn't a lipo configuration!
And besides, farther down the Twin Star II web page, Tower recommends two different NiMH packs for the plane.
So yes, the projected weight presumes a NiMH pack.
- Jeff
jdetray is offline
Old 07-16-2006, 11:33 AM
ragbag
My Twin Star is still on the shelf. I don't own a nicad/nmh battery so everything I have is lipo powered.
Probably a 3s1p2200, I know I will have to modify the battery area. That isn't my problem, I want landing gear so till I work that out it will sit on the shelf.
Look at these posts elsr where in the Wattflyer on the Twin Star II:
http://www.wattflyer.com/forums/show...8514#post88514
ragbag is offline
Old 03-27-2008, 02:55 AM
jaywalker
Sarge
I use Electrifly 7 cell flat 3000 Mah NiMh batteries. I put a 2 1/2 " foam block in front of the battery to maintain CG. You can expect 10-15 min flights on that.The neat thing is I also use 2 of these in series to power my Magister, so with 7 batteries I can fly both planes a long time .
jaywalker is offline
Old 04-28-2008, 09:38 AM
stinkweed007
stinkweed007's Avatar
I used a 11.1v 1600 3c lipo.. kept off the throttle and it worked fine.. that was yesterday
stinkweed007 is offline
Old 04-28-2008, 12:46 PM
jaywalker
Sarge
Talking Twinstar 2 Lipos
I use a 2S lipo 4230 Mah Flight Power. I think the 3 cell will shorten the motor life. Also I put in Speed 480 motors and 7X4 props. It will carry 10 oz of camera /xmtr gear very well. I had to add a small lipo for the camera because I was getting horizontal lines on the FPV googles. Hope this helps.
Old 04-29-2008, 09:36 PM
Aero Ace Ace
Aero Ace Ace's Avatar
If you plan on using the stock motors, then avoid using a 3s lipo. A 2s lipo has a little less voltage than a 7 cell, so you might want to try upgrading the props to get a little more thrust.
Aero Ace Ace is offline
Old 04-30-2008, 12:39 AM
jaywalker
Sarge
One reason I fly the TS2 is the abililtiy to land on grass without breaking props. It does a good job hauling cameras etc. I saw a thread on Multiplex "Movie Star" looked like what I need to carry heavier weight but it's been discontinued. I wonder if any other plane would have the cargo space it does ?
Thanks for any info.
Old 04-30-2008, 01:36 AM
3s is fine - if you keep the amps down to 9-10 or so (for decent life). A 2s is about like 6.5 NiMh Cells, so that will work with the stock props well too. Mike
Old 05-03-2008, 12:46 AM
everydayflyer
Southern Pride
everydayflyer's Avatar
Not LiPolys but........................
http://www.rcuniverse.com/forum/m_5934960/tm.htm
everydayflyer is offline
Old 05-09-2008, 03:54 PM
supi7
TrueRC.com
supi7's Avatar
2S lipos will be much better power than Nimh can provide. the Voltage under load will be higher then Nimh so it does not matter that 8cell Nimh has higher Voltage. under load it sags lower then the lipo.
2S 3200mAh or 4000mAh pack should run really well. also 2x 2100mAh packs in parallel will do the trick.
Also as everydayflyer suggests LiFePO4 cells would be great and a 3 cell pack would power really nicely.
Dan
TrueRC
supi7 is offline
Old 05-13-2008, 04:30 AM
Mike Freas
Hey guys.
I'm thinking about throwing one of these together for MWE this weekend. Plan was to save money off the batt and use the stock motors on a 3s. I know those little 400's don't like 12 volts but I'm not all that worried about long life with them and plan on going brushless in the future. I wanted to know how many amps they pull with the stock props so I know what ESC I need to get. Thanks.
Mike Freas is offline
Old 05-13-2008, 04:52 AM
Kosh
Kosh's Avatar
A single 30 amp ESC will cover both motor and I have tested it on mine a few times with 3 cell packs.
Kosh is offline
Old 05-13-2008, 01:58 PM
jaywalker
Sarge
I am using 2S Lipo "Flight Power" and 35 ESC (I can program either type battery in 10 seconds in the field) with 2 Speed 480 7,2V motors. It carrys a lot of camera weight and I get long flights. You can also alternate with the 7 Cell NiMh . I use 7X4 e props and they really move. I'm guessing 60 MPH plus.I converted mine to 7 chn FASST receivers and mix Rudder and Aileron for smooth camera flights. Really a great plane 40 flights no crashes -------Yet !!!!!
Old 05-13-2008, 03:56 PM
jaywalker
Sarge
That's a 4270 mah lipo.
Old 05-14-2008, 05:59 AM
Smiky
I'd rather be flying...
Smiky's Avatar
I have a 10 year old Twinstar Mk1 and fly it on a 3s A123 pack. It's lighter than the old 2000mAh 8.4V Nicad's I used to have in it and a lot more power!
Smiky is offline
Aero Ace Ace
03-27-2008 12:16 AM
sdavismil2000
ParkFlyers
03-02-2008 11:22 PM
peterpont
01-25-2008 10:40 PM
Quick Reply: What LiPo for TwinStar II?
Page generated in 0.09894 seconds with 13 queries
