Lion battery voltage discharge
Old 02-11-2021, 04:33 AM
Mustangdude
Mustangdude's Avatar
Default Lion battery voltage discharge
Can anyone tell me the lowest safe voltage should be on my ZOHD 2s 3500MaH battery?
Is it the "End Voltage"? If so it would have a voltage of 5.0 volts, is that correct?
Here's the spec sheet.
Thanks, Jim
Mustangdude is offline
Old 02-11-2021, 05:59 PM
Past President of PSSF
I would not go below 3v as an absolute minimum and don't go below 3.3volts in general practice. My buzzer goes off at 3.5 volts on some of my planes, but sometimes I get a quick buzz on a heavy draw, then the voltage comes back up. If it buzzes steady, I land.
If you go too far, the battery may not charge back up.
Wildflyer is online now
Old 02-11-2021, 06:33 PM
https://www.instructables.com/How-to...0specification.
According to various online .... 18650 LiIon are often discharged to between 2.5 and 3.0v at which auto-cut-off occurs. But unprotected cells will of course carry on till user switches it off.
It is advised on 3.7V nominal (4.2V max) LiIon 18650's to not go below 2.8V ... but recc'd not to go below 3.0V .. with 3.2V even better.
My Radioking TX has a two 18650 cell power pack in it and my alarm sounds at 6.6V .... (3.3V per cell).
Old 02-11-2021, 09:39 PM
Mustangdude
Thanks guys, just what I needed.
06-28-2017 04:22 PM
01-09-2017 02:23 AM
37
04-21-2014 10:28 AM
Gmanjr
Foamies
16
06-03-2012 06:07 AM
FlyingBrick50
Heads UP RC discussion
11-21-2011 10:18 AM
Quick Reply: Lion battery voltage discharge
Page generated in 0.09661 seconds with 15 queries
