CoG?
Old 05-12-2019, 11:04 PM
trying2fly
Default CoG?
When using a "wing CoG calculator...where on the wing do you measure the "chord"? thanx!
trying2fly is offline
Old 05-13-2019, 01:23 AM
Jools
Jools's Avatar
The GofG position must be calculated from the wing AREA. E.g. 28% of the AREA should be AHEAD of the CofG point, and 72% of the area should be BEHIND the CofG. I'll use 28% as a very realistic example).
For a simple wing planform like a simple taper:
Measure the halfway point of one wing (span-wise). Make a line from LE to TE parallel with the wing root at that point.
On this line measure 28% back from the leading edge. Mark this point.
Make a line from this point to the wing root at right angles to this line and the wing root.
Balance the aircraft on this point. That will be 28% of the Mean Chord.
Swept wings and more complex wing planforms will need a different method.
Jools is offline
Old 05-13-2019, 01:45 AM
trying2fly
Thank you so very much!!!!!!!!!!!!!!!!!!
Old 05-13-2019, 07:45 AM
Past President of PSSF
The chord of a wing is simply the total leading edge to trailing edge distance measured parallel to the centerline of the fuselage.
Measured at the center of wing gives you the root chord, measure at tip gives you the tip chord.
Then you can make a search for a good CG calculator.
Here is just 1 --- https://www.google.com/url?sa=t&rct=...cgFKeO6bDV52VK
Wildflyer is offline
Old 05-13-2019, 02:47 PM
trying2fly
thanx a lot...that was what I was after!!!!
Old 05-13-2019, 02:58 PM
Just to add a bit (not necessary for a flying wing) ... but for later reference ...
Root Chord is the Leading Edge to Trailing edge measurement of a wing in cruise mode without flaps / slats extended ... and measure where wing joins the fuselage minus any extensions for jet intakes etc.
Just commenting ...
thepiper92
Foamies
14
12-02-2013 06:10 PM
250rman
08-13-2013 10:40 PM
npowell28
Foamies
10-18-2012 08:21 PM
npowell28
04-19-2012 05:13 PM
Alabama Flying Dude
Electric Ducted Fan Jets
04-05-2011 06:41 PM
Quick Reply: CoG?
Page generated in 0.07948 seconds with 13 queries
