Crash and Safety Forum Punch something in lately? Have safety suggestions? Tell the story, share safety tips, and show the pictures here.
Found!!!
Old 03-18-2015, 03:34 PM
hkeelljr
Default Found!!!
Yesterday I posted that my G370 dissappered after flying over some woods and getting caught in some turbulent air. Today I and happy to report I managed to find it partially intact, the prop was broke, everything else appeaares to ok. Haven't tested the mottor or anything like that yet,hopefully I didn't burn up the esc or motor.
hkeelljr is offline
Old 03-19-2015, 03:07 AM
LOL, glad you found it!
Old 03-19-2015, 08:59 PM
theapplepi3.14
Totally Non-Newtonian
theapplepi3.14's Avatar
Do the more experienced guys have GPS trackers on their planes? Particularly the long range FPV guys?
theapplepi3.14 is offline
Old 03-19-2015, 10:36 PM
gadgeter
It's a Possibility!
gadgeter's Avatar
I lost one of mine once and the lips was shot from running down. Check that
I have a beeper on some of mine but GPS gets a little impractical.
gadgeter is offline
Old 03-19-2015, 10:45 PM
theapplepi3.14
how big are your aircraft? sure having a 1/4lb device on a 1lb aircraft is kinda dumb but if you have a 100lb, $5000 fpv distance flier I would imagine the $30 expense would be worth it...
Old 03-20-2015, 12:07 AM
Glad you found it. Thank goodness if wasn't out in the wild long enough to turn feral.
Years back I lost a nice balsa Biplane on its maiden. I was young, and dumb, and balanced it on the lower wing. This put my CG back by quite a bit.
I got her in the air and somehow managed to keep it undulating at about 150 feet. It would drop 20 feet, gain speed and loft back up 20 feet. I somehow managed to keep this going for about 200 yards as the wind pushed it along, pretty deeply into some thick woods, in August. In hindsight, i should have just dropped the throttle and at least salvaged some electronics. It had a big AXI, 4 new HB65's, a pricey AR6000, Align 35 amp ESC and a $50 2000mAh 3s in it. Again, these were 2009 prices.
Couldn't find it in the thick thorn and mosquito infested woods for many hours.
Finally, no kidding, on Christmas Eve. I stopped by the flying field. I saw my wing sticking out of a trash can! Battery was gone but that was it. AR6000 was full of water. I replaced the bearings in the HB65's and still fly then in a foamy. ESC Still works, in another foamy. Motor got new bearings but magnets came loose. Most likely rust.
Here is an item I wish I would have used. I doubt it has a low voltage cutoff so could ruin a battery but a plane with a ruined battery is better than a lost one with a good battery.
http://www.headsuphobby.com/Signal-L...nder-C-440.htm
Old 03-20-2015, 01:34 AM
carpetbagger
that headsupRC lost signal alarm was on sale a couple weeks ago, picked up three for my fleet. Suckers are LOUD
carpetbagger is offline
Old 03-20-2015, 07:40 PM
hkeelljr
Guess I'll have check out those alarms out. I feel extremely lucky that nothing else besides a prop was damaged. Also I checked out the motor and esc and the servo's and they check out. Haven't checked out the battery yet/
hkeelljr is offline
Old 03-28-2015, 02:08 PM
hkeelljr
As promised here is a photo of my G370 after its epic adventure.Click image for larger version
ID:	179989 Its still hard to beleive that the wing or the whole plane wasn't shredded on its way down but hey, I'm thankful that even found it to begin with.
hkeelljr is offline
Humor
11-03-2014 08:20 PM
Beemerider
11-12-2012 10:20 PM
BroncoSquid
02-26-2012 07:25 PM
ryanespana
iTrader talk
09-30-2011 10:49 PM
earthsciteach
Off Topic Chit Chat
10
05-29-2011 02:43 AM
Quick Reply: Found!!!
Page generated in 0.09836 seconds with 12 queries
