Go Back  WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Special Interest Aircraft
Reload this Page >
Inflatable RC Planes: The Future of Slow to Medium Speed RC Flight?
Old 03-04-2015, 11:08 PM
theapplepi3.14
Totally Non-Newtonian
theapplepi3.14's Avatar
Default Inflatable RC Planes: The Future of Slow to Medium Speed RC Flight?
Last year I built an inflatable RC plane. The idea worked well as a proof of concept, but it will need some more work before it becomes a true RC aircraft. It also takes, hours, and hours, and hours... and hours to build. The result of all that hard work? A plane that can take most any crash without any repairs, can be stored in a crayon box, can use wing morphing, works really well at low Reynolds numbers, and can be fixed by covering any breaks with tape, then be re-inflated. It's only weakness of course is very rough or sharp things, but depending on the material thickness and choice, this problem can be significantly reduced.
theapplepi3.14 is offline
Old 03-04-2015, 11:27 PM
FlyWheel
Ochroma Pyramidale Tekton
FlyWheel's Avatar
"Crash without any repairs"? Hell, fill them with helium and they would be practically crashproof. Flyaways may be a problem though...
FlyWheel is offline
Old 03-05-2015, 12:33 AM
Didn't someone make a round one at some point? Kinda like a giant ducted fan? Similar to this but inflatable.
Old 03-05-2015, 02:11 AM
theapplepi3.14
What is that bad-boy called?
Sadly the electronics will probably make the plane heavy enough that adding helium won't make it fly away. It would increase endurance though, especially on a fat delta wing!
The materials for the plane are really cheap. I spent $40 on a roll of material, and after 3 planes I have not been able to see a measurable change in the thickness of the roll. The manufacturing process would be pretty expensive though, especially if they are made by hand. It would cost $70 dollars in human labor in america if the system were mast produced by hand, or $7 in India(WARNING: Political Satire!). Just imagine keeping your 1/16 scale plane in your glove compartment, or your 1/2 scale plane in your duffel bag! Plus, It has a higher stall angle! Anyone want one? All you need is a mini-iron and a large sheet of mylar, and... wait for it... wait for it...wait for it...a massive amount of MATH!
BTW: before I balanced the model I crashed it strait into the hardwood ground at a good 10mph with homemade soldering on a circuit board 2 inches from the nose, and after probably a dozen such crashes I saw no deterioration in the plane, or in the delicate electronics!
Old 03-05-2015, 02:19 AM
Someone was converting inflatable pool toys to fly recently. Lol!
Old 03-05-2015, 02:32 AM
theapplepi3.14
haha. Pool toys have wings that are cylindrical, the math i referred to is used so that you get an actual wing shape
Old 03-05-2015, 02:47 AM
Wow, here is an interesting find!
http://www.rexresearch.com/lippisch/lippisch.htm
Old 03-05-2015, 03:14 AM
gramps2361
gramps2361's Avatar
Here you go on the inflatable pool toy RC airplane this was flown at Neat Fair in NY.
Found it there is a better video of this inflatable pool toy, but this is the one I just found. If I track down the better one I will post it.
http://youtu.be/TtoAAGN0EG8
gramps2361 is offline
Old 03-05-2015, 12:04 PM
theapplepi3.14
Wow! Im surprised the pool toy actually worked! Mine is more efficent though
Crash and Safety Forum
2155
02-09-2019 09:50 AM
06-28-2017 04:22 PM
01-09-2017 02:23 AM
Doc Austin
3D Flying
01-05-2013 03:19 AM
hayofstacks
03-05-2012 12:07 AM
Quick Reply: Inflatable RC Planes: The Future of Slow to Medium Speed RC Flight?
Page generated in 0.09300 seconds with 14 queries
