RCU RSS Feed RC Unviverse General Electric Discussion forum rss feed
Big electrics, guys lets see what you are flying
Old 09-15-2006, 07:10 AM
RSS Feed
Default Big electrics, guys lets see what you are flying
Myself and a couple buddys fly some Ok size electrics. Here are a couple to check out. Drop me a line and lets see what big electrics are being flown....
More...
RSS Feed is offline
Old 09-15-2006, 06:07 PM
rcjake
Here is one of my larger aircraft that has been converted to electric. It is the Hangar 9 P-40 arf. Here are the specs and a few photos.
PJS 3D 5000 Brushless Outrunner Motor
Castle Creations 110HV ESC
(1) Poly RC 3700mAh 4s + (1) Poly RC 3700mAh 3s battery packs in series
1700mAh Ni-Mh battery pack for the rx & servos
MPI HD Switch w/LEDs
Flying Weight 8lbs
Flies faster than a H-9 P-40 powered with a Saito 100
Name:	Mounted Engine.jpg
I will post info and photos of my Great Planes 160 Size Ultimate later today. 16lbs and flies like it has a 50cc gas engine in it...only better!!!
Jake
rcjake is offline
Old 09-17-2006, 06:02 AM
rcjake
Here is the skinny on my Great Planes 160 Size Ultimate Biplane.
PJS 3D 10000 Brushless Outrunner Motor (Direct Drive...no Gearbox!)
PJS 22 x 12 Electric Carbon Fiber Prop
MGM 12032-3s Z-Series 120amp ESC
(2) Poly RC 7300mAh 5s2p Lipo packs wired in series
2100mAh 6v Ni-mh Battery Pack for rx & servos
Flying Weight 16lbs
Name:	Jake & Ultimate.jpg
Name:	LR Ground Shot.jpg
This is one great flying bipe! From the time of take-off until I land, everyone watches and many cannot believe that it is electric powered!
It takes off in about 60' and then can go straight up...rolling...as far as I want to go!
I love flying this Ultimate!!!
Jake
rcjake is offline
Old 04-01-2008, 09:54 PM
photors
Default what big electrics are you flying
I currently have 3 lg electrics.
E-Bird of Time
Some goofy ebay monster 130in wingspan
Red Baron conversion
photors is offline
Old 05-22-2009, 04:05 PM
MaxAdventure
AMA 198798
MaxAdventure's Avatar
Default Let's see those 'big' electrics!!!!
In an e-flight world dominated by park fliers, let's see some 'big' electics! Revive this thread and post your + 4lb +48" span birds!!!
Having flown glow for 25 years I really like planes I can see in the air, come in smooth for landing and aren't knocked across the field in a light breeze!
I have a scratch built AP platform based on an old Eagle 63 wing with optionsal tip extensions that take it from 60" to 108" on 6S aprox 1200W
I'm still doing tests and have cut down the vertical stab, added cooling, build a camera mount since this photo. I am continuing to modify and will end up glassing and painting the fuse.
I also have a .40 Kyosho spitfire conversion on about 4S 600W
and an electric 2.6M DG100
I know I asked for pics and I don't have many - I promise to take some and post soon!
MaxAdventure is offline
Old 05-22-2009, 04:19 PM
Well let's see
6' Telemaster Electro
Axi 2812/12 Jeti 18 amp ESC, 3s 5000mah lipos.
1/4 Scale Great Planes Shoestring
Welgard 4130/08, Welgard 80 amp HV ESC, 8s 4000mah lipo
6' span AUW 8.2 lbs, top speed (so far) into a 15mph headwind, 78 Mph
Flagship of the fleet Cox 1/5th Scale Waco YMF-5
Cox 4130/08 and Cox 90 amp Opto ESC, 8s 4000mah lipo
6' top wingspan, 12.5 lbs AUW
Old 05-22-2009, 05:33 PM
Nitro Blast
Nitro Blast's Avatar
Holy Thread Ressurection Batman!
Ok heres my big Yak!
Great Planes 25% Yak 54
PJS 10000 Motor
MXM 100 amp controller
Futaba 8ch RX
Polk Tracker III Tx
Tanic 5s2P 7700 mAh x 2 batteries
APC 22x12 prop
Name:	FEAR 08 (12).JPG
Nitro Blast is offline
Old 05-22-2009, 07:40 PM
MustangMan
MustangMan's Avatar
OK, I've got big plane envy! thanks alot
I saw Bill's Shoestring and Waco at SEFF. Both beautiful airplanes and sweet flyers too.
Someday I'll pull the video of your Waco flight at SEFF out of the camera Bill...:o
My Hyperion CAP 232 25e (Wattflyer Buyers Club Item #2), when it arrives, will be the biggest bird in my fleet. At least until I finish building the 60" Electricub:o.
MustangMan is offline
Old 05-22-2009, 10:46 PM
Liquidity
Combat Vet
Liquidity's Avatar
My biggest electric is either a 6' telemaster or Deuces Wild.
Largest nonelectric is a Giant Stinger powered by a 51CC Area 51 engine
Liquidity is offline
Old 05-23-2009, 01:14 AM
Very soon I will begin putting together my 27% Pitts M-12. I got my motor from Big Mike a week or so ago and can't wait to get her going now.
I have a Hacker A60-18M with a Castle HV85 ESC to go into it.
Old 05-23-2009, 04:33 AM
vax6335
Crazy 'bout Bees
vax6335's Avatar
This is my biggest electric so far. 60" Clancy Big Bee. Turnigy 4260-500 and 70 amp esc, 13x6 APC, and two 3s 3200mah lipos in series. Around 33 amps and about 730 watts at full throttle.
vax6335 is offline
Old 05-23-2009, 07:13 AM
Larry3215
Look out for that tree!!!
Larry3215's Avatar
Ive had several big electrics and keep getting or building more
My Great Planes 160 Ultimate was a 2600 watt setup. Awesome flyer. A real adrenalin rush.
I traded it for the 30% KMP Yak and moved the power system over to it and added cells to get to 3200 watts. Another awesome flyer. I sold the airframe on it and the power system is awaiting a new home.... TBD
I currently have several large foamies Im flying that go from about 1000 watts up to about 1500 watts.
The Mega Capricorn is my altime favorite plane. Span is 60" and length is about 90". Wing area over 3300 sq inches. Its curently flyign right at 1000 watts peak on a 6S1P A123 pack.
The XXL Polaris and 84" long x 60" span and is running a 6S2P A123 pack at about 1350 watts peak.
The Foamy Yak BUFY v2.0 is 74" span and runnig a 6S1P A123 pack around 1100 watts.
My FlyFly F86 is running a 7S Lipo at around 1500 watts. Its a 60" span.
Name:	3-20-08 011 (Medium).jpg
ID:	101658   Click image for larger version
Name:	IMG_5095 (Medium).JPG
ID:	101659   Click image for larger version
Name:	IMG_5132 (Large).JPG
ID:	101660   Click image for larger version
ID:	101661   Click image for larger version
Name:	IMG_4438 (Medium).JPG
Larry3215 is offline
Old 05-23-2009, 08:16 AM
Hi Everyone here is my 80" W/S Scratch built Foamy Biplane My Friend Steve is doing the maiden flight on it
[media]http://www.vimeo.com/3917006[/media]
view this video in full screen at YouTube, you can see it better
[media]http://www.youtube.com/watch?v=UWepNtYW8gs[/media]
Old 05-23-2009, 08:18 AM
You Have to many Nice Toys Larry Take Care, Chellie
Old 05-23-2009, 04:35 PM
LipoPilot
Flown A Lipo Lately?
LipoPilot's Avatar
Biggest plane I got so far built.
A-26 Invader
50"WS Pink Foam
Powered By Twin 2409-12
Lipo 7.4 2500 and 11.1 2200
Maiden her last weekend...have flown again since the prop loss and plan to film her again in the morning
[media]http://vimeo.com/4707053[/media]
LipoPilot is offline
buzzbomber
02-24-2010 12:39 PM
Sky Sharkster
04-16-2008 03:11 PM
lmopar69
12-08-2007 12:48 AM
canadagoose
10-01-2007 11:32 PM
aircruiser
08-05-2006 05:58 AM
Quick Reply: Big electrics, guys lets see what you are flying
Page generated in 0.10168 seconds with 19 queries
