Pairing 2 Lipo Queastion
Old 02-11-2018, 10:30 AM
Emilinoz
Default Pairing 2 Lipo Queastion
I have a queastion; If you were to take 2 Lipo Batterys say 3cell each @ 2200mah each,but one is 20c Rated and the other 30c Rated and joined them together- at wich C rateing would the motor draw? 20c Constant or 30c Constant; Dont know if ime right or not but i would say 20c- My reason is because its rated at 20c and you wouldnt be able to draw 30c from a 20c rated battery? Am i right or way off and wat would be the affect if you went ahead with this set-up,Dont get me wrong i wouldnt attempt this at all but ive always wondered wat the outcome would be.Emil.
Emilinoz is offline
Old 02-11-2018, 11:21 AM
Ideally if pairing two batteries (series or parallel) you would use batteries of the same C rating. Having said that for moderate or low demand applications it will be ok to use different C ratings. You take the rating of the lowest battery, so as you suggest in your example that would be 20C.
Old 02-11-2018, 12:58 PM
It depends on whether series or parallel ...
In series then you would have to regard the lower C rating as your marker. Not advised to have different rated packs - but it happens ! Series adds the Voltage but leaves mAh same.
In parallel - then technically you can push harder and have a composite C rating - BUT it is not advised and could lead to problems. The theory being that the load has been divided because volts remain same but mAh increased.
In practical terms : It is common for twin packs to be used - but it is advised to use same size / C rating and even brand - to ensure balanced use. It is also advised that both should be at same state of charge when coupled ... to avoid surge from higher to lower ...
Old 02-11-2018, 09:59 PM
Emil it wouldn;t matter unless your set-up required more than 20C, not forgetting that your 20C battery may not be capable of a true 20C anyway. However if your plane only had a current requirement of 10C - 15C it wouldn't matter at all. It would do no harm to either battery.
SimonXi
08-17-2011 12:02 PM
SimonXi
08-12-2011 06:08 PM
Quick Reply: Pairing 2 Lipo Queastion
Page generated in 0.04754 seconds with 13 queries
