am I ask'in to much of this plane? A-10 GWS
Old 10-20-2008, 02:03 AM
Bub Steve
Bub Steve's Avatar
Default am I ask'in to much of this plane? A-10 GWS
GWS A-10,,,Theres HUGELY differant opinions on the Brushed-Verses-brushless, I want one but can't afford another brushless twin set-up but have all the stuff for brushed (And a brushed-lipo/nicad ESC-25)and plan to use a 1600 3 cell on her, as those that know me know how Light I build (24Oz formossa11) am I ask'in to much of this plane? I'd like to order her but I don't want to sink a bundle-o-$ on her to get-her-go'in, thanks ,, ya'll's bub,steve
Bub Steve is offline
Old 10-20-2008, 02:07 AM
The Don
Balsa Butcher
The Don's Avatar
I had a very nice flying GWS A-10 it was when they first came out. EDF50 brushed setup with a 7 cell 700 mah NiMh pack. No landing gear. I also flew it on a 2S lipo as well. You needed WOT all the time but it was doable.
Don
The Don is offline
Old 10-20-2008, 02:13 AM
CrazyAggie05
T-38 Driver
CrazyAggie05's Avatar
It is very doable. It is what I will do whenever I get around to building it. There are lots of guys on rcgroups.com using the EDF55 setup with the stock brushed motors running off a 20-25A ESC and a TP 2100 3S.
CrazyAggie05 is offline
Old 10-20-2008, 02:30 AM
Bub Steve
Bub Steve's Avatar
Thanks guys::I've noticed that most the threads I've read said they were fly'in um at 24-29 Oz But the fly'in weight on the manual says 12.7-14.46oz, have'in said that,,are these guys build'in lead-sleds or is GWS weight est, WAY OFF?bub, steve
Old 10-20-2008, 03:02 AM
CrazyAggie05
T-38 Driver
I think some are building lead sleds because they are putting high power dual ESC setups in there with 3s LiPos. Because of that extra power, they are putting CF all throughout the wings AND fuselage and some have even glassed and painted it. I think if you are going to do it with stock brushed motors and a 3s Lipo you would only need a little CF in the engine nacelle mounts, wings, and fusealge around where the wings mount and thats it. Build her light!
Old 10-20-2008, 03:31 AM
Bub Steve
Bub Steve's Avatar
Default Thanks sooo much to Don and you for help'in me out here
CrazyAggie05::I like um light and always build with less poundage than kit say it'll be, but when I saw dozens of post say'in 24+Oz I thought the 14-17 was a infamous GWS tran's screw-up the manuals are famous for ( I'm sure you've noticed!!) Thanks sooo much to Don and you for help'in me out here as I'm a newbie to EDF models and Love the Wart-Hog!!your bub, steve
Name:	petty an red 390.jpg
ID:	81073   Click image for larger version
Name:	petty an red 387.jpg
ID:	81074   Click image for larger version
Name:	petty an red 406.jpg
ID:	81075   Click image for larger version
Name:	petty an red 762.jpg
Old 10-20-2008, 05:34 AM
CrazyAggie05
T-38 Driver
No problem dude, keep us posted on the build
Old 10-20-2008, 06:20 AM
Crash Test Dummy
Crash Test Dummy's Avatar
I'm guilty!! I built a heavy A-10!! I glassed and painted her all up and then to be sure it had enough power I mounted a 480/1020KV outrunner in her butt!! I would suggest putting a CF spar across the entire Horzinal stab in the rear. It is prone to breaking there if you make it a belly lander. If you are running gear you could save the weight and leave it out. The wing saddle is another weak part on the A-10. Some put carbon rods inside the fuse and some will glass just the wingsaddle with 3/4oz. FG cloth and epoxy. Just some thoughts........
The link below is of my A-10, pop some popcorn and enjoy the movie!!
http://media.putfile.com/A-10-480-outrunner
CTD
Crash Test Dummy is offline
Old 10-20-2008, 09:09 AM
Alpea42
Parkjets Rule 3D Rocks
Alpea42's Avatar
Guys I watched this one fly today but didn't find out what he used for power other than the stock EDFs. It flew but only adaquately no extra thrust. Yours with the 480 as a pusher is way faster C.T.D.
Name:	Flying field 10-19-08 011.jpg
ID:	81110   Click image for larger version
Name:	Flying field 10-19-08 012.jpg
ID:	81111   Click image for larger version
Name:	Flying field 10-19-08 021.jpg
ID:	81112   Click image for larger version
Name:	Flying field 10-19-08 023.jpg
Alpea42 is offline
Old 10-20-2008, 01:14 PM
CrazyAggie05
T-38 Driver
Looks like that one has the old 3 blade edf 50s?
Old 10-20-2008, 06:20 PM
fr4nk1yn
^_^
fr4nk1yn's Avatar
This is getting me interested in the A-10 again. I passed on it because the guy at the LHS said it would barely fly on the stock setup.
Brushless kits then were expensive but with HC I could pull it off.
fr4nk1yn is offline
Old 10-20-2008, 06:27 PM
ministeve2003
Class Clown
ministeve2003's Avatar
actually he said it was stock.. I'm assuming that ment brushed ?... with 2200 3cell pack, and he said it was very stable, just not enough power for him... and I felt it... it was a lead sled... It prob would fly fine on stock bushed, so long as you keep the battery weight down... prob go with 2cell 1000-1300mah pack.... and it should fly great... you could also try the pusher mod... that would prob help alot...
SK
ministeve2003 is offline
Old 10-20-2008, 06:41 PM
Bub Steve
Bub Steve's Avatar
I was go'in brushed with a 1600 3cell, I'm start'in to have 2'nd thoughts here, I just finished another twin with outie's an I just can't $$$ another twin right now but have the brushed lipo-nicad 25amp ESC at the ready and hoped it would do, thanks , bub,steve
Old 10-20-2008, 06:48 PM
ministeve2003
Class Clown
to be honest with you, I haven't built one yet, the only referece that I have is other similar size/weight gws kits like the formosa, I use a single 22amp 45gram motor with a 1000mah 3cell pack on the formosa1 and get 2:1 or 3:1 thrust, but I know that with edf's you need twice the power, so I'd assume you could go with brushed motors around 40grams each and that should be ok with 1600 3cell packs... might be a little heavy, but that will be ok, because its not intended for a 3d setup...lol
SK
Old 10-20-2008, 07:03 PM
Bub Steve
Bub Steve's Avatar
SK
I'll be happy if it'll ROG and climb out, bub, steve
Old 10-20-2008, 08:48 PM
Alpea42
Alpea42's Avatar
"Haven't built one yet" HUH Steve? LOL
Alpea42 is offline
Old 10-20-2008, 11:21 PM
vax6335
Crazy 'bout Bees
vax6335's Avatar
Steve I've got one of these stashed under my workbench, I'll be keeping an eye on what you decide to do also. I'd rather not invest a lot in mine either, so I may go with a somewhat stock setup.
Keep in mind, the full scale versions aren't really hot rods either!
vax6335 is offline
Old 10-20-2008, 11:52 PM
Bub Steve
Bub Steve's Avatar
vax6335:A few of the kids in my RC youth club "Mullet Marauders" are egg'in me on two get it( their fly'in 4 Ch this year), I'll go on and order it and do my darn'dis to keep her light by use'in white gorillla glue (weightless when cured)and spilt bamboo, like I do my chuncker builds, Fly'in mullet's have been a problem lately and we in our club strive to keep the sky's over our fare Hamlet, (Shadeville.Fl.)clear of the most vile fish,( unless their smoked with crackers and hot-sauce), And a A10 may help get the low one's dart'in for the coast,,, yet, I degress,,,, thanks , your bub, steve
Old 10-21-2008, 12:17 AM
CrazyAggie05
T-38 Driver
Say what?
Dude quit worrying and build this @#$@# with the stock brushed setup and a TP 2100 3s. It will work! See this below:
http://www.rcgroups.com/forums/showthread.php?t=834706
Old 10-21-2008, 01:27 AM
Bub Steve
Bub Steve's Avatar
Originally Posted by CrazyAggie05 View Post
Say what?
CrazyAggie::Thanks for the Great Link my bub,To some it's a little thing (New Store bought plane) but until quite lately 120$ (by the time she maid'in's ) Been a Butt-Load -0-$$ for me to throw around and be'in my first EDF after 40+ years of model'in I need some guide'in from my bub's here, If you look at what I've been build'in the last few years (cheap-chunckers)you'd understand my be'in a might giddie about a Real-Plane, your bub, steve
ID:	81149   Click image for larger version
ID:	81150   Click image for larger version
ID:	81151   Click image for larger version
Name:	petty an red 248.jpg
ID:	81152   Click image for larger version
Name:	petty an red 469.jpg
Name:	petty an red 493.jpg
ID:	81154   Click image for larger version
Name:	petty an red 576.jpg
ID:	81155   Click image for larger version
Name:	petty an red 645.jpg
ID:	81156   Click image for larger version
Name:	petty an red 464.jpg
Old 10-21-2008, 02:19 AM
Alpea42
Alpea42's Avatar
I like your "cheap chunkers " Steve. The A-10 might be a little too advanced for the young pilots of The Mullet Marauder Club. But if they want to watch you fly it then Go For It.
Alpea42 is offline
Old 10-21-2008, 02:46 AM
Bub Steve
Bub Steve's Avatar
Alpea42::I've had 11-12 year olds in the club who make my heart nearly stop with their fly'in antic's!! bub, steve
Name:	petty an red 094.jpg
ID:	81165   Click image for larger version
ID:	81166   Click image for larger version
ID:	81167   Click image for larger version
ID:	81168   Click image for larger version
Name:	petty an red 381.jpg
Name:	petty an red 615.jpg
ID:	81170   Click image for larger version
Name:	petty an red 446.jpg
ID:	81171   Click image for larger version
ID:	81172   Click image for larger version
Name:	petty an red 635.jpg
ID:	81173   Click image for larger version
Name:	petty an red 619.jpg
Old 10-21-2008, 02:52 AM
CrazyAggie05
T-38 Driver
Haha looks like ya'll are having fun! I am diggin the Franken-planes especiall the yogurt cup cowlings. Thats pretty inventinve! You should enter in the scarp built planes contest over on rcgroups.com.
Old 10-21-2008, 04:12 AM
Bub Steve
Bub Steve's Avatar
They ran my ass-off years ago!! HaHaaa!! bub, steve
Name:	petty an red 709.jpg
ID:	81181   Click image for larger version
Name:	petty an red 194.jpg
ID:	81182   Click image for larger version
Name:	petty an red 538.jpg
ID:	81183   Click image for larger version
Name:	petty an red 359.jpg
ID:	81184   Click image for larger version
Name:	petty an red 436.jpg
Name:	petty an red 676.jpg
Old 10-21-2008, 04:21 PM
Alpea42
Alpea42's Avatar
My 10 year old rebuilds crashed planes. And when he got ready for his 1st solo flight he insisted on takin up a rebuilt Stryker. LOL And got it up and down successfully. Now I don't even stand near him when he flys and Chellie said last Sun. as we watched him fly that he was becoming a really good R/C pilot.
Alpea42 is offline
Page generated in 0.14256 seconds with 47 queries
