Three Phase Alternator - Three Phase Motor? - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Brushless Motor Construction Discuss design and construction of custom Brushless motors
Old 01-31-2015, 09:40 PM
Default Three Phase Alternator - Three Phase Motor?
I've posted this thread in RCGroups that shows a video of two standard brushless motors directly wired to each other. That makes one an alternator, the other a motor.
Take a look at this thread:
http://www.rcgroups.com/forums/showt...4#post30651764
https://www.youtube.com/watch?v=gc9TP95VoZk
Old 02-01-2015, 01:52 AM
pmullen503
Interesting, any practical application for this?
pmullen503 is offline
Old 02-01-2015, 02:19 AM
Nope
IMHO, none what so ever for modeling use anyhow
Old 02-01-2015, 04:28 AM
Turner
Turner's Avatar
This is basically the way diesel electric locomotives work.
Turner is offline
Old 03-11-2015, 10:33 PM
theapplepi3.14
Totally Non-Newtonian
theapplepi3.14's Avatar
I envision a plane with two driven motors that are in sync with the driving motor which is powered by the recoil of a machine gun so that the plane can fly with two blades very close together and a gun shooting through the blades (timed by the recoil spinning the motor) but it will only fly if the gun is constantly on! moohahahaha!
theapplepi3.14 is offline
Old 03-12-2015, 07:42 PM
Larry3215
Look out for that tree!!!
Larry3215's Avatar
Nope
What? Wait just a second! Are you trying to tell me I cant hook up a second motor to my main motor and use it as a generator to power the main motor?
Nononono, Im sure if you put them both inside the right kind of pyramid and maybe add some extra magnets in just the right positions to match the star positions, it would work!
Larry3215 is offline
Old 03-12-2015, 08:23 PM
Of course you could always buy a Hacker A200 15 KiloWatt motor on a giant scale model. Then put a smaller motor and prop windmilling to generate power to run the receiver/servos.
By the time you get it to work, you've spent more time and $$$$ than just getting a big LiFe or A123 battery pack to do the same job. Or, just buy a HV uBEC!
Old 03-12-2015, 08:35 PM
Larry3215
Larry3215's Avatar
Naw, I like my perpetual motion ideas better
Old 03-12-2015, 09:09 PM
theapplepi3.14
You could invest money in Antman's technology and then buy a million-man-microbe-size mercenary military to man the machinery inside the motor, making many megawatts, moving the prop, and making the plane move
Old 05-02-2015, 09:36 AM
PJBruno
I'm researching high altitude long endurance setups and this is the most accessible solution for intermittent battery charging using an on board IC engine.
A large 22 foot span soaring airframe with twin 64mm EDF's gives me plenty of room for fuel and charging gear. Eventually the goal is to build a matching alternator or generator for my Lipo charging circuit. Until then this is a great solution for charging a battery system with liquid or gaseous fuel.
A fuel driven pico turbine/gearbox setup with solar photovoltaic wing skins is the dream but time and funds are limited.
A build log is coming but I like to build and fly more than log or shoot video. With a 2200mah battery and great conditions the bird will stay aloft for just over ten hours on autopilot.
PJBruno is offline
Old 05-02-2015, 02:55 PM
Turner
Turner's Avatar
Originally Posted by PJBruno View Post
...With a 2200mah battery and great conditions the bird will stay aloft for just over ten hours on autopilot.
What is the purpose?
Turner is offline
Old 05-06-2015, 04:03 AM
PJBruno
The idea of a long endurance aerial platform came out of a request for a search and rescue prototype that was low cost enough to lose in a maritime environment.
Now the idea is to provide a flexible platform for science or imaging payloads in the form of modules. I've been working on measuring surface wind speeds over a large area of Northern Lake Michigan in preparation for another project. That payload can be swapped in a few minutes to fit a high resolution camera.
Most of my work is custom ROV and marine instruments. RC was a hobby in my teens and getting back to this kind of "work" has been lots of fun.
PJBruno is offline
Old 05-09-2015, 06:13 PM
dereckbc
You bet there is. It is the basis of almost all over unity SCAMS. Great way to rip people off like HHO systems for your car.
dereckbc is offline
Old 12-09-2018, 01:19 AM
ron_van_sommeren
homo ludens modelisticus
ron_van_sommeren's Avatar
An electrical gearbox.
rpmout : rpmin = #magnetsgen : #magnetsmot
ron_van_sommeren is offline
Old 12-20-2018, 06:48 PM
Why use EDFs?
A big prop and low kV motor will use less than half the power for the same level of flight performance.
quorneng is offline
Old 12-26-2018, 01:40 AM
dereckbc
Deleted, repeat.
dereckbc is offline
02-25-2018 12:51 PM
06-28-2017 05:22 PM
01-09-2017 03:23 AM
02-16-2016 01:19 AM
12
02-04-2014 07:05 AM
Quick Reply: Three Phase Alternator - Three Phase Motor?
Page generated in 0.12115 seconds with 11 queries
