About Lipo Chargers
Old 11-14-2020, 03:17 AM
Suprawill1
Default About Lipo Chargers
Hi All,
As far as discharging, I realize most chargers won't apply much current to discharge a lipo. In fact, when I'm discharging a 3200mah 6S, it will only go to 0.8 amps. My question is then, when I discharge a 2200mah 2S, why does it go up to 2.2 amps?
Will
Suprawill1 is offline
Old 11-14-2020, 11:49 AM
Its all about WATTS ....... or as most chargers do - create heat via resistors to 'burn' off that energy.
Very few chargers have setup where the energy can be passed to another lower receiver as in regenerative.
Think about your 6S pack at 0.8A .... lets say you start at 4V per cell ... that's 24 x 0.8 = 19.2 W
Now take your 2S pack at 2.2A .... 8 x 2.2 = 17.6 W
If your 6S was to hit 2.2A ... that would be 24 x 2.2 - 52.8 W ...
Check your manual for total max W discharge ... very few can handle significant amps ..... watts ......
Old 11-14-2020, 07:32 PM
Suprawill1
Thanks for your post. I was advised that my charger has a 20 watt capacity for discharge. 6S would eat that up 3x as quickly as 2S would. It makes sense now.
You were more explanatory.
Old 11-14-2020, 07:52 PM
I corrected my post - I mistakenly said 3S .....
20W is about usual for many chargers .... and you also will find you may never hit 20W due to losses in cables etc. So the 19W in the calc's is actually about best you can expect.
Old 11-14-2020, 08:59 PM
Suprawill1
I saw an option for "regenerative" while scrolling through the settings. Is that what you spoke of earlier concerning slaving an additional power soak?
Old 11-14-2020, 09:52 PM
I may have used wrong term ... but I think thats the one.
Some chargers allow you to connect another battery to bleed of the excess charge to. In fact I have a discharger for my DJI batterys that recharges mobile phones / tablets etc - anything that takes 5V USB style rates.
Most are still limited ampage though .....
I think you'll have to read carefully your manual ................. What charger is it ??
Old 11-14-2020, 11:08 PM
Suprawill1
Turnigy Reaktor 300W 20A
and
Detrum Supermate DC6
Old 11-15-2020, 02:13 PM
OK ... Reaktor : as per manual .... yes the Regenerative means you can put up to 300W from discharging battery into the battery providing the chargers power .... that is if you are powering from a 12V car battery etc. Of course you cannot direct that to a mains adaptor power supply !
Old 11-15-2020, 08:31 PM
Suprawill1
Oh, ok. Good to know. Thanks for this info!
SimonXi
08-17-2011 12:02 PM
SimonXi
Batteries & Chargers
08-12-2011 06:08 PM
HeliScRapYard
03-14-2011 02:02 PM
Quick Reply: About Lipo Chargers
Page generated in 0.11770 seconds with 12 queries
