New Spektrum Receiver, the AR500
Old 04-26-2009, 12:10 PM
Tony Oliver
Hi Travis! the 'whisper' was because I don't want to set up an 'off-topic' discussion
However as it was a valid question you posed about it being a correct comment, I agree there are times when it may be appropriate.
The boat people have a reservation about using 2.4ghz gear as they think it will have no range over water. Especially with spray around. Small boats may be unable to get the antenna high enough to operate at a good distance and still be in 'line of sight'. However the distance involved with small boats in my experience is very close when compared with what the limits are likely to be. My belief is that the worry is unfounded but it's not difficult to arrange a higher antenna whatever the situation. If that is applied to water planes of any sort, once in the air they will be as normal, and who will be flying at water level hundreds of feet away? It's a topic open for experimentation with repeatable results so that all this sort of 'here be dragons' unsubstantiated allegations can be refuted and killed off (or corroborated?) once and for all. There seem to be reservations about spray, wet leaves(?) and foliage between the transmitter and receiver. Spray may be a problem, but operating radio gear when flying/sailing behind some obstacle seems a bit of a daft exercise anyway. Do we do that regularly or occasionally? I am quite happy to fly behind something as long as the failsafe works and recovers very quickly, but I doubt I've actually done that more then two or three times in 50 years of using RC gear. Even then it was not a voluntary thing and was due to pilot error or misreading the situation.
Tony Oliver is offline
Old 09-03-2009, 12:37 PM
ama51668
ama51668's Avatar
5 channel? 4 channel? 3 is just right for me, and for sure ymmv.
i prefer flying speck high and speck wide with old timers and glider types - so a full range rx is what's required - and my dx5e and ar500's get the job done perfectly.
ama51668 is offline
Old 12-18-2009, 08:12 PM
shimsham
Ar500 v Ar6200. Cant decide which to go for as i have the Dx7 going to be a tight decision
shimsham is offline
electrodude71
05-10-2008 04:17 PM
Andrew James
04-08-2008 02:58 AM
electrodude71
03-22-2008 06:05 AM
floridawen
03-18-2008 01:38 AM
Gohmer
03-16-2007 02:08 PM
Quick Reply: New Spektrum Receiver, the AR500
Page generated in 0.07153 seconds with 12 queries
