Some people ask me how I check control surface movement .....
Old 02-24-2021, 10:15 PM
Default Some people ask me how I check control surface movement .....
Printed / drawn onto stiff thin card ..... it can be inserted into the gap between the moving surface and adjacent fixed ... taped or pinned to stop it moving while surface deflects up / down etc.
Its funny actually .... most people quote mm movement on plans etc. - but I prefer degrees as then its more related to the way the surface scribes an arc. The above card lends itself easily to that.
Old 02-25-2021, 03:37 AM
RKTLaunch
Using mm doesn't make sense...an aileron may be narrower than an elevator... making where you measure relative.
Degrees are absolute. The length or distance makes no difference.
RKTLaunch is offline
Old 02-25-2021, 04:36 PM
Yes degrees are absolute - but the mm are related to the surface stated for .... so ie 5mm on a narrow chord control will mean more degrees than 5mm on a wide chord control.
11-02-2021 02:03 PM
05-27-2020 06:48 PM
08-13-2013 11:29 PM
propduster8
12-13-2012 02:42 PM
04-09-2012 01:57 PM
Quick Reply: Some people ask me how I check control surface movement .....
Page generated in 0.07135 seconds with 11 queries
