Motors and Speed Controllers for sale & WTB List your brushless or brushed motors and speed controllers for sale in here
For Sale Multiplex Easy Star 2 Adjustable Aluminum Motor Mount
Old 06-29-2012, 09:59 AM
terrynshed
Default Multiplex Easy Star 2 Adjustable Aluminum Motor Mount
This CNC machined aluminum two piece mount is designed to adapt a large range of outrunner motors to the new Multiplex Easy Star 2. It will allow for three different motor mounting heights to accommodate propeller sizes ranging from 7" to 9".
With this feature you can easily run a lower KV motor with a larger propeller for more thrust and better efficiency. This would be a perfect combination for FPV pilots looking for longer flight times and a more quiet platform.
Swapping motors from a 35mm outrunner with a 9" prop to a 28mm outrunner with a 7" prop can easily be done by removing a few screws. This is ideal for those looking to achieve the best performance possible.
Position 1: stock height up to a 7" prop.
Position 2: (+) 0.41" for up to a 8" prop.
Position 3: (+) 1.0" for up to an 9" prop.
Three step installation:
1. Attach motor base plate to the stock plastic mount with 4 supplied pan head screws (On the two smaller holes, the screws will thread through the plastic and into the aluminum base)
2. Attach new motor to motor plate with 4 supplied flat head screws.
3. Attach motor plate to motor base at desired height with 4 suppled pan head screws.
Included: 1 - Motor Base Plate and Motor Plate, 4 base screws, 4 motor screws, and 4 mount screws.
Total Weight: 16g
*** This is for the NEW Multiplex Easy Star 2. ***
Notes:
- The stock folding spinner can be utilized with different sized props and motosr with a 3mm or 3.17mm motor shaft.
- A 35mm outrunner motor will only fit in position 3 (+ 1.0"). 28mm outrunners will work in any of the three positions.
- For motors utilizing a 'bolt on' propeller shaft, only positions 1 (stock) and 3 (+ 1.0") will work properly due to the motor shaft sticking out of the back of the motor.
- The stock thrust angles are retained in all 3 positions. If a change in thrust angle is desired, simply add a small washer between the motor base and motor plate at the appropriate locations.
Center of Gravity should always be checked and adjusted per the user manual after installation of a new motor.
These are manufactured by Small Parts CNC. Please visit for more RC products.
Price is $15.95 with fixed shipping of $2.00 in the US and $4.00 International. Please send me a PM if you are interested or have any questions.
Thanks for looking!
ID:	160983   Click image for larger version
ID:	160984   Click image for larger version
ID:	160985   Click image for larger version
ID:	160986   Click image for larger version
ID:	160988   Click image for larger version
ID:	160989   Click image for larger version
ID:	160990   Click image for larger version
ID:	160991   Click image for larger version
terrynshed is offline
terrynshed
04-07-2021 06:25 AM
PilotNYC
Foamies
18
06-24-2012 10:47 AM
terrynshed
02-01-2012 06:11 AM
terrynshed
02-18-2011 05:11 AM
Quick Reply: For Sale Multiplex Easy Star 2 Adjustable Aluminum Motor Mount
Page generated in 0.09269 seconds with 23 queries
