EC3 Connectors + 12AWG wire
Old 03-13-2009, 07:39 AM
DKNguyen
Default EC3 Connectors + 12AWG wire
Can anyone tell me if 12AWG wire will properly fit into EC3 connectors? I only see premade assemblies with them that are 13AWG at most. I'm kind of curious why such a strange wire gauge (odd), since most wire gauges are even (ie. 26, 24, 16, 12, 10, 8)
DKNguyen is offline
Old 03-13-2009, 03:22 PM
constantCrash
prefectionist
constantCrash's Avatar
I managed to fit 10AWG in an EC3. It was NOT easy. 12AWG is probably possible but have a BIG soldering iron with a big wedge type tip.
Here's a thread on my pain:
http://www.wattflyer.com/forums/show...ight=EC3+Rhino
Also, I really like the knockoff EC3's better than the E-flite EC3's the knockoffs are made of a softer plastic that make it easier to get the bullets in.
http://www.hobbycity.com/hobbycity/s...idProduct=7182
constantCrash is offline
Old 03-13-2009, 05:27 PM
Twmaster
Registered User
Twmaster's Avatar
Knock off EC3's?? Good god.
Oh, yes 12GA wire will fit. Be sure to tin both the plugs and the wire to aid in finishing the connection.
I use a Weller soldering station that makes 50W of heat and have had no problems soldering this sort of setup.
I too have done 10GA. Loads of fun. (NOT)
Twmaster is offline
Old 03-13-2009, 05:32 PM
gfdengine204
gfdengine204's Avatar
I'm placing an order for 20 of these. I like Deans, but hate taking them apart. Figure I'll start with 20 (at $1 each, can't resist that) and go from there.
gfdengine204 is offline
Old 03-13-2009, 05:41 PM
Twmaster
Registered User
Twmaster's Avatar
The real ones are less than $3 a set. I just got my order of 3 sets in from Atlanta Hobby.
Dean's are good connectors but too much work IMHO. No mucking with shrink wrap and simple assembly. I'm changing all my connectors on higher power setups to EC3.
Twmaster is offline
Old 03-13-2009, 05:47 PM
gfdengine204
Yeah, but you make the big bucks!
Old 03-13-2009, 05:55 PM
constantCrash
prefectionist
I like the knockoffs better because of the softer plastic. They have a better feel to them. It also doesn't hurt that they are 50 cents per set (HC sells them $1 / pair which when i purchased 10 of them, i ended up with 20 sets of male/female. (this might have been a mistake on their part but for the moment I don't have to worry about connectors.) They are cheap enough that I can use them throwaway. at $3.00 a set i wouldn't do that as i'm not rich.
Sometimes name brand is just a name.
Old 03-14-2009, 03:56 AM
DKNguyen
THe thing that amazes me about Dean's is how the designers expect to solder a wire to a flat solid tab and have it hold.
THe reason I askis because I have a couple 100 foot rolls of 12AWG wire lying around and the my Spektrum RX has EC3s on it. I'm going to use EC5s for the motor driver and power systems, but I was just wondering if I was going to have to chop off the EC3s and replace em.
DKNguyen is offline
Old 03-15-2009, 01:07 AM
nzreg
I like using the EC3 and EC5, but, they are a pain to disconnect. That is until I came up with the idea of using a tapered piece of plastic that slips between the connectors and gently pushes them apart.
nzreg is offline
Old 03-15-2009, 01:49 AM
Dr Kiwi
You can get Bullet or MP Jet Gold Connectors up to 4mm (these will take 120A, and some others to 6mm presumably can cope with more) - a piece of cake to solder these!
Dr Kiwi is offline
John-NYC
Batteries & Chargers
09-12-2008 04:40 AM
SJB
08-23-2008 07:01 PM
diverdon
07-15-2008 02:57 PM
PerlAddict
27
03-22-2008 05:53 AM
cloud-9
Foamies
17
12-31-2007 10:39 PM
Quick Reply: EC3 Connectors + 12AWG wire
Page generated in 0.12873 seconds with 12 queries
