Eflite Power 60 static thrust?
Old 03-13-2009, 02:39 AM
imsofaman
Default Eflite Power 60 static thrust?
Guys....I have an Eflite 60, 16x10 APC prop, HXT 80 amp ESC and using A123 cells 6S2P. So....I hooked up the digital fish scale to the tail gear and measured my static thrust. It is only 6.5 lbs. Isnt that low? I was hoping for like 8 lbs or so.
What am I doing wrong???
Dave
imsofaman is offline
Old 03-13-2009, 03:30 AM
Dr Kiwi
What's your rpm? Give us that and we can figure out if it's your motor or your measuring equipment.
Dr Kiwi is offline
Old 03-13-2009, 03:35 AM
imsofaman
OK.....I will let you know im a minute.
Old 03-13-2009, 03:44 AM
imsofaman
I cant get get a good reading. I think it is too dark in the basement. The numbers were all over the place.
I will check in the morning......
Dave
Old 03-13-2009, 04:55 PM
imsofaman
OK....look like it is spinning around 6000 rpm. Even in the sunlight, the numbers fluxuate up and down a bit. But I believe it is spinning at 6000 rpm.
Dave
Old 03-14-2009, 02:13 PM
imsofaman
Just to let you know....what ever the thrust is....it was enough to lift my 9 lb autogyro. I think I may try a few more props to figure out what pulls hard but not to exceed the rated amperage draw. The photo attached was taken befor the conversion.
Old 03-15-2009, 01:02 AM
Dr Kiwi
It is near impossible to find thrust data in any of the calculators for that 16x10 APC E... the only thing near it is a 16x10 CAM folder which comes out, in Badcock, at ~3500g (7.67lb) @ 6000rpm.
Dr Kiwi is offline
Old 03-15-2009, 01:45 AM
imsofaman
Dr Kiwi,
Thanks so much for taking the time in helping me. I am still going to try more props in different pitches. The difference is weight from using a 91 four stroke to using the electric system is only 8 oz. heavier. I could have gone 6S1P and the pack would be light...but would only give me probably 4 min. of flight at best. So...I doubled up with 2P.
Again, thanks so much.
Dave
Old 03-15-2009, 02:44 PM
imsofaman
Some pics of my conversion....
ID:	96308   Click image for larger version
ID:	96309   Click image for larger version
ID:	96310   Click image for larger version
ID:	96311   Click image for larger version
ID:	96313   Click image for larger version
rcproptester
03-12-2008 02:48 AM
Kip Jackson
12-10-2007 04:11 AM
orionRider
Electric Ducted Fan Jets
10
03-08-2007 12:28 PM
RSS Feed
RCU RSS Feed
10-18-2006 02:40 PM
rcboatnut
03-02-2006 12:14 AM
Quick Reply: Eflite Power 60 static thrust?
Page generated in 0.10102 seconds with 20 queries
