help with putting lipos in super cub
Old 03-25-2009, 02:59 AM
gramps2361
gramps2361's Avatar
Default help with putting lipos in super cub
My wife got me a sc for a birthday present.
I have 2 lipo's 7.4v 1300 mah 20c Can I just use these in the cub without doing anything to the esc. I realize the esc will detect the lipo but what about the cut off level for the battery.
gramps2361 is offline
Old 03-25-2009, 03:26 AM
Gramps I don't own a SC so I can't comment for certain but I do not think the ESC is lipo compatible. You can probably run one ok but the low voltage cutoff won't happen at the right time if you run it too low.
As long as you don't fly it too long it won't hurt it. You just have to be aware of your times.
Old 03-25-2009, 03:32 AM
flydiver
flydiver's Avatar
Lipos should not go below 3.0v/cell under load or ~ 3.7v/cell resting.
The Cub DOES have a jumper that can be removed to make it 3S lipo compatible-a better performance upgrade anyway. See the jumper here:
http://supercubclub.proboards78.com/...lay&thread=988
Don't remember where the LVC for NiMh is but it'll be lower than the 2S lipo (probably ~ 5v) so flying to LVC will kill your lipos. If you fly ~80% of your current Nimh time, land and check the voltage and do small adjustments you can get away with it as long as your voltage is > 7.4v when you land.
There is no adjustment for 2S LVC. There is no replacement without replacing everything.
Don't expect a big performance boost-likely modest at best if at all.
flydiver is offline
Old 03-25-2009, 04:07 AM
gramps2361
gramps2361's Avatar
Hey thanks to both of ya. It was a thought to try it since i have these kicking around. Instead of playing with it I think i'll just leave it nihm's for now. Have other plane that i use these in.
Old 03-25-2009, 04:12 AM
gramps2361
gramps2361's Avatar
flydiver good thread I thought it was weird that I couldnt locate esc everything is built into one unit that's kinda scary.
Old 03-25-2009, 04:41 AM
flydiver
flydiver's Avatar
Parkzone - a LOT of their stuff is proprietary. Folks love their Cub until they start running up against the limitations of the electronics. They are decent for a newbie application but ultimately cheap and frustrating. Change anything but the motor and you have to change everything.
That site I pointed you at is largely about flying, then modding the Cub. It's a good resource. Do some reading there. Pretty much any question you think to ask has been asked a couple hundred times about that plane.
flydiver is offline
SilverMopar
04-20-2009 06:36 PM
ralph99
02-12-2009 02:07 AM
crash_expert
08-08-2008 02:19 PM
GreenAce92
ParkFlyers
11
12-05-2007 11:47 PM
aircruiser
Scale E-Powered Aircraft
11-28-2006 06:33 PM
Quick Reply: help with putting lipos in super cub
Page generated in 0.08912 seconds with 15 queries
