SIG Kadet LT-40
Old 03-07-2016, 08:01 PM
Its almost easier to get a wing kit and build anew wing than to change the dihedral if they glued the wings together.
If it comes apart its not a lot easier...
You have to separate the wing panels. That means a razor saw if the wings are glued together.
Then remove the center sheeting to access the dihedral bracing structure.
Saw out the braces, preferably without cutting the spars
Then block the wings in the desired alignment
Cut the new dihedral bracing pieces and check their fit (without glue)
Complete the reassembly and re-sheeting then fix the covering.
With a lot of building experience behind me... I'd just build a new wing from scratch...
Note that some of your issue can be corrected by just putting on larger ailerons and adjusting "differential throw"
this would be simple and quick.
Old 03-07-2016, 08:05 PM
Jack_K
Jack_K's Avatar
Thanks. I was afraid of that.
Jack_K is offline
Porcia83
18
04-15-2015 07:49 PM
Kraydune
03-22-2015 09:58 PM
dheaton
13
05-06-2014 05:27 AM
hanick
10
02-16-2014 04:56 AM
brutus
05-06-2012 11:58 PM
Quick Reply: SIG Kadet LT-40
Page generated in 0.09454 seconds with 14 queries
