Prop difference
Old 08-16-2022, 06:26 PM
jangodog
jangodog's Avatar
Default Prop difference
I need a prop for my 2800-2200kv and 2200-1000kv brushless. But there are two versions:
https://www.motionrc.eu/products/apc...ack-lpb08038sf
And this one:https://www.motionrc.eu/products/apc...lack-lpb08080e
what does “slow flyer” means?
jangodog is offline
Old 08-17-2022, 09:09 AM
Slow Fly props are crap !!
They are thin wide blade props usually in nylon that flex a lot. You definitely do not want to use on a high KV motor. I stopped using them om low KV motors as they lack 'punch' when throttle opened .... you can hear the WOMP of the blade flexing.
The 2200KV motor is most likely a 6x4 E prop ...... APC or similar.
The 1100KV probably in the 8" and up range.
You need a Wattmeter to test and decide what is best prop along with thrust test using a simple fishermans scale.
Old 08-17-2022, 10:32 AM
jangodog
jangodog's Avatar
Okay. I’ll go with non slow fly prop in the scale you suggest. Hook up my wattmeter too.
Thank’s
jangodog is offline
Old 08-17-2022, 06:25 PM
To be fair a slow fly prop "does what is says on the tin". It more efficient at the low power levels likely with a slow flying plane.
"Very much horses for courses".
quorneng is offline
Old 08-18-2022, 07:50 AM
jangodog
jangodog's Avatar
I’ll go wiith a regular APC prop. Thank’s.
jangodog is offline
05-28-2020 09:50 PM
SoCal Perky
05-07-2017 07:29 AM
Beemerider
05-21-2013 07:01 AM
Alabama Flying Dude
Pusher Park Jets
05-19-2012 04:13 PM
11-26-2011 10:09 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Quick Reply: Prop difference
Page generated in 0.08761 seconds with 9 queries
