What kind of battery connector is this?
Old 07-02-2013, 02:06 AM
Dspanky1505
Default What kind of battery connector is this?
Hey all,
I'm trying to get back into the hobby, and all of my batteries are too weak, so I need to buy some new ones. I was a newbie years ago when I started, therefore I am still a newbie, so my terminology is a little elementary. I was hoping you guys could fill me in on what kind of battery connector this is so that I know what kind of battery to get. I know that it is a 7 cell nicad battery, but that is about all that i know. Thanks in advance!
Dspanky1505 is offline
Dspanky1505
Old 07-02-2013, 02:37 AM
hayofstacks
hayofstacks's Avatar
let the nicads go. time for an upgrade.
hayofstacks is offline
Old 07-02-2013, 02:48 AM
Dspanky1505
Thought about it, but seeing as it is a trainer, it probably wouldn't be worth the money for lipo's and a new motor. But then again, I haven't priced them in a while. Someday when it is time for a new plane, yes. But for now being a neighborhood flyer/crashed....nicads are getting the job done.
Old 07-02-2013, 02:54 AM
hayofstacks
$5-10 for a similar priced lipo, 2-3 times the flight time, about 5 times the power. if your old.batteries.are toast, now is the time.
Old 07-02-2013, 02:59 AM
hayofstacks
use the lipo with existing motor and esc. just need to be careful of low voltage cut off.
Old 07-02-2013, 03:07 AM
Dspanky1505
That would be compatable, eh? Always thought it was a no-no. What do you mean by the cut off?
Old 07-02-2013, 03:11 AM
To answer the original question, that is a Mini Tamiya connector
Old 07-02-2013, 03:19 AM
Dspanky1505
Thank you!
Old 07-02-2013, 03:24 AM
hayofstacks
Smile
lipos shouldn't get much below 3.7's per cell. most esc's have a built in low voltage cutoff to prevent destroying your lipos. my dad had a brushed slowstick he ran on nicads. when the pack quit, he threw a jst connector on and used his lipos t(400-800mah 3 cells) from broken helicopters. it dramatically changed both power output and flight times, and weighed less then half what his nicads did.
once you get a taste for it, I doubt you'll go back. good luck either way you go.
Old 07-02-2013, 03:56 AM
Hey all,
Yeah
As others have indicated, I've also gone the way of the Nicads and Nih cells for electric motor power. That said, those LiPo batteries are an order of magnitude better than those old units. And if you shop around, they are also cheaper.
But, you absolutely must have a charger that balances the LiPo batteries through the LiPo battery balance connector while charging these things.
A wide variety of balancing chargers are available nowdays. As for me, I've gone the Cellpro line, such as the Cellpro Multi4 chargers. (Cellpro also has a store in the USA)
http://www.store.revolectrix.com/Pro...pro-Multi4_220
Old 07-05-2013, 04:17 AM
Hey all,
Connectors are the old standard TAMIYA plug used on cars / brushed motor planes for years ... but so temperamental ... they have been replaced in general use by Deans, XT60's etc.
Old 07-05-2013, 04:19 AM
Trouble is LiPo's either low or too high a voltage compared to NiXX packs ... ask me how I found out !!
Really you need to swap out motor as well as the battery if you want to do LiPo ... so means Brushless motor, Brushless ESC and LiPo to suit.
Old 07-05-2013, 04:36 AM
LOL
Sounds like the voice of experience!
Here is why one of those wattmeters is so important when working with different types of battery packs, motors and propellers. Increasing the battery voltage by 25% could wind up doubling the watts input to your motor, while using the same propeller. Not to mention putting to much voltage on your ESC, and blasting it in the first second of powering it up.
If your ESC can handle the extra voltage, generally with the use of a wattmeter, you can select a propeller that will allow running your motor within its ratings.
Old 07-05-2013, 04:39 AM
flydiver
flydiver's Avatar
7-cell NiCad fully charged = 9.6v
2S (2-cell) lipo fully charged = 8.4v
But the lipo will be lighter and support the voltage better so the plane should fly better. If the battery is an important part of the balance (CG) you should pay attention to the weight and size if that's a consideration also.
You'll find NiXX batteries are fading away in RC. You'll pay as much or more for a NiXX battery as you will for a similar lipo. You probably have a Ready To Fly (RTF) plane so the charger isn't much of a shake either. No loss to get rid of it. This is the time to upgrade batteries AND charger.
The low voltage cut-off for brushed ESC (speed controls) for the NiCad will be too low and damage the lipo if you fly until the motor quits. You'll need to fly awhile, land, and check the voltage until you can figure out a decent time to fly. You can use a voltmeter or there are cheap voltage checkers available for a few $$, well worth having.
Ditch the Tamiya connectors. They are lousy.
flydiver is offline
Old 07-05-2013, 10:36 AM
Hey all,
Hi, Thats not a Nicad battery but a NiMH , 7 Cell @ 8.4 Volts
Nickel–metal hydride battery
Old 07-05-2013, 10:45 AM
You Can Roll your Own Battery Pack these are a 700 mah Ni MH battery, It looks like yours are a 600 mah, these will work just fine, they should not be to much heavier if at all, Because of new Generation Ni MH tech.
http://www.onlybatteries.com/showite....31&cat1=&uid=
Old 07-05-2013, 10:56 AM
These Ni MH batteries are not cheap, But at least you wont have to buy a new charger for lipos, ASAP get into lipos, You will be glad you did, Chellie
http://www3.towerhobbies.com/cgi-bin...?&I=LXAYNU&P=0
http://www.hobbypeople.net/index.php...shed-rtf.html#
Old 07-05-2013, 11:12 AM
http://www.hobbypeople.net/index.php...male-1-pr.html
05-28-2020 09:50 PM
10-11-2016 01:52 AM
03-11-2012 07:51 AM
03-11-2012 01:40 AM
Otonzer
02-26-2012 12:01 AM
Quick Reply: What kind of battery connector is this?
Page generated in 0.09663 seconds with 13 queries
