Seaplanes E-Powered Discuss electric powered seaplanes here
Flying Boats Noob Questions
Old 10-14-2008, 11:38 AM
phupper
Flyin' Phup
phupper's Avatar
Default Flying Boats Noob Questions
I want to make a flying boat to fly on the bay (salt water) near my house. I know most people dont fly on salt water because of the damage it does to electronics, but Im doing it anyway. Of course everything will be waterproofed as best as possible. I only have one 25A motor for this project so Im considering making a Dornier Wal. It has 2 motors in a push-pull setup, so I would just omit the rear motor.
My questions are:
I like the idea of sponsons instead of outboard floats. With no floats to snag the water, are these planes easier to land?
I also like how the motor is mounted high on the wing. If it did flip up-side-down, wouldnt it float on the wing with just the motor submerged and the fuse out of the water?
Also, if anyone could direct me to existing plans for this plane Id appreciate it..otherwise Im working from 3-views.
Thanks!
Phil
phupper is offline
Old 10-14-2008, 06:19 PM
TLyttle
TLyttle's Avatar
Suit yourself about flying over salt water, but it is very likely to cost you a radio...
As far as the single motor is concerned, it may be worth it to gear your motor to a shaft to drive both front and rear props.
TLyttle is offline
Old 10-15-2008, 12:12 AM
phupper
Flyin' Phup
phupper's Avatar
"Suit yourself about flying over salt water, but it is very likely to cost you a radio..."
Yeah I know, using my least-valued electronics for this. I have beautiful flying weather every day and not many places to fly. This big empty bay next door just says "fly me".
I think much of the damage is caused by the way the plane sits in the water after it flips, and that's why I'm considering the Dornier.
Phil
phupper is offline
Old 10-16-2008, 02:05 AM
cyclops2
Default Go for it.
My first flying boat. Roughed out from solid foam. 4...400 motors.
Name:	China Clipper.jpg
cyclops2 is offline
Old 10-16-2008, 02:18 AM
Bub Steve
Bub Steve's Avatar
Cyclops Wow! that really something!! good job my bub, steve
Bub Steve is offline
Old 10-16-2008, 02:32 AM
Bub Steve
Bub Steve's Avatar
phupper Salt waters a No-No!! have'in said that,," motor is mounted high on the wing. If it did flip up-side-down, wouldnt it float on the wing with just the motor submerged and the fuse out of the water?" ,, Yes,,, my tail lays back an the motor doesn't even get that wet,,,""I like the idea of sponsons instead of outboard floats"" I use both!HaHa! A GWS foat un-trimed gives a Butt-Load- buoyincy And there Cheap too, your bub, steve
Name:	petty an red 217.jpg
ID:	80795   Click image for larger version
Name:	petty an red 221.jpg
ID:	80796   Click image for larger version
Name:	petty an red 248.jpg
ID:	80797   Click image for larger version
Name:	petty an red 298.jpg
ID:	80798   Click image for larger version
Name:	petty an red 300.jpg
Name:	petty an red 359.jpg
ID:	80800   Click image for larger version
Name:	petty an red 484.jpg
ID:	80801   Click image for larger version
Name:	petty an red 305.jpg
ID:	80802   Click image for larger version
Name:	petty an red 453.jpg
Old 10-16-2008, 06:38 AM
phupper
Flyin' Phup
phupper's Avatar
"my tail lays back an the motor doesn't even get that wet"
Thanks Steve, that's what I was hoping to hear. I've already started on the fuse/hull. If it gives me trouble I'll go with the GWS float (I didn't know they made them that big).
I like the way your motor is forward, allowing a larger diameter prop. I'm concerned I may not have enough thrust with the motor I'm using, and the smaller prop I'll have to use.
Thanks!
Phil
phupper is offline
Old 10-16-2008, 06:45 AM
Bub Steve
Bub Steve's Avatar
When up-side-downzie in the water the tail,the motor nacell and the top side of one of the wings is what she floats on, bub steve
Old 10-16-2008, 06:50 AM
Bub Steve
Bub Steve's Avatar
Thanks!
Phil
Shes got a 2409-18 outie(25 ESC&1600three cell))swing'in a 9/7 cut down to 8", The planes just two chunker gliders chopped together with barbie skewers , your bub, steve
Old 11-17-2008, 11:26 AM
phupper
Flyin' Phup
phupper's Avatar
Well, here's the link to what I came up with:
http://www.wattflyer.com/forums/show...671#post506671
Phil
phupper is offline
Old 12-02-2008, 02:10 AM
fairplane
Default waterproofing electronics
Did you know that there are 2 good products for waterproofing electronics? One is aeroplate and the other is corrosion X. I have submersed servos and receivers in aeroplate when flying on freshwater lakes(nitro planes).These products should help with what you want to do. You can do research-they are remarkeable!
fairplane is offline
Page generated in 0.10849 seconds with 25 queries
