Can you add a power switch to a stock Belt C/P? - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 09-16-2008, 09:31 PM
Zeddi
Question Can you add a power switch to a stock Belt C/P?
Hi,
My stock Belt C/P does not have a Power switch. This becomes problematic when I plug in the battery and the gyro is trying to initialize and I end up moving the Heli (small accidental movement, the connectors are a tight fit). Plus I have to remove the canopy to power off the heli. This brings me to the question. Can you mount a simple switch on the +lead before it gets to the speed controller? Or do you need to switch both +-leads? More importantly has anyone done a similar mod without replacing the speed controller or rx/tx. I have been searching the forums but havent found a mention.
Thank you,
Zeddi
Zeddi is offline
Old 09-16-2008, 10:24 PM
theecoop
theecoop's Avatar
you could install a switch on the pos(+) before the ESC
theecoop is offline
Old 09-16-2008, 10:54 PM
Zeddi
Thx,
That is what I was wondering. Should I worry about amp ratings?
Zeddi is offline
Old 09-16-2008, 11:58 PM
theecoop
theecoop's Avatar
always make sure the switch is rated proper
theecoop is offline
Old 09-17-2008, 12:48 AM
Mysterious
any success, I wanted to do this for my belt cp but could not find an apprpriate switch
Mysterious is offline
Old 09-17-2008, 01:03 AM
theecoop
theecoop's Avatar
even though not seeing a rating , but by seeing wire gauge being used this should work well
http://www.heli-world.com/detail.aspx?ID=2514
But I recommend contacting them to make sure
theecoop is offline
Old 09-17-2008, 06:19 AM
Zeddi
Thumbs up found a switch and mod successful
Ok,
Thanks for all the info and timely response. I went down to radioshack and bought a DC 30A switch, with a blue led in the lever which I thought was perfect however it is larger than I had envisioned. Anyway after relocating the esc (to the nose above the battery) I wired in the switch. It works great and the combination of additional forward weight from both the switch and esc help to balance my tail heavy STOCK Belt cp. Again thx for the info.
Zeddi is offline
rcflyair
10-09-2007 03:47 AM
32
08-31-2007 03:04 PM
pl365322
62
08-14-2006 06:20 AM
Heidelberg Germany Flyer
09-19-2005 06:55 PM
Quick Reply: Can you add a power switch to a stock Belt C/P?
Page generated in 0.05628 seconds with 13 queries
