Brushless motor won't spin - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Brushless Motor Construction Discuss design and construction of custom Brushless motors
Old 07-17-2007, 05:58 PM
Pconn5
Default Brushless motor won't spin
I just purchased this esc and brushless motor combo.
http://cgi.ebay.com/ws/eBayISAPI.dll...9888&rd=1&rd=1
I started everything up and turned the motor on it started spinning fine then all of a sudden i heard a loud grinding noise. I turned it off immediately. It happened again after i tried again. Now the motor won't turn at all it just studders back and forth a little! What could be wrong did i fry something? Also im using a 7.4 volt lipo to power it.
Pconn5 is offline
Old 07-17-2007, 07:28 PM
cbusse1
Default Call Jeff
You bought it from Heads Up Rc. The owner, Jeff, is a great guy and he stands behind his products. e-mail him or give him a call and I'm sure he will help you out.
Have you examined the motor closely? There may be something caught in it that is preventing it from turning. These are cheap motors and maybe a screw fell out and got lodged inside somehow. Small metal objects like screws are attracted by the strong magnets inside the motor and I have had some get caught in there while I was mounting the motors to the motor mount.
Take a magnifying glass and get a close look.
Good Luck,
cbusse1 is offline
Old 07-17-2007, 08:26 PM
Pconn5
OK i sent him an email. I checked everything closely and nothing seems to be jammed at all. The esc wont go through the normal start up sequence anymore but everything still has power.
EDIT: He has tested an esc and motor and is going to ship me out the new one and im shipping him back mine. He has amazing customer service!
Pconn5 is offline
Old 07-18-2007, 08:37 PM
d&mrc
d&mrc's Avatar
I have bought this same motor 3-4 times. I have used it on all my planes, save the new mini ultra stick I just got. My latest one has the sam problem you are describing! But, that esc has been through many crashes, and several planes......
d&mrc is offline
Old 07-18-2007, 10:01 PM
FlyingMonkey
Flite Test Fan
FlyingMonkey's Avatar
I had something like this happen. Turned out that the little "C" clip that holds the shaft, came off, and the magnets sucked it inside the bell housing. Check in there.
FlyingMonkey is offline
Old 07-18-2007, 10:04 PM
Grasshopper
Some Assembly Required
Grasshopper's Avatar
I also had a motor do that once. The thing just sat there and stuttered as you described. I reprogrammed the ESC and all was good.
Grasshopper is offline
Old 07-20-2007, 11:26 AM
Sky Sharkster
Sky Sharkster's Avatar
Default Check The Wires?
Hello Pconn5, I had a similar problem, turns out it was the wiring. Here's the thread;
http://www.wattflyer.com/forums/showthread.php?t=10973
Just another idea!
Ron
Sky Sharkster is offline
Old 08-14-2007, 05:00 PM
MTDV
I had a problem with mine also, but I used ESC CC-10 with a home made CDrom motor. The motor could not keep up with the ESC, so it failed at high power climb during take off. This caused the airplane plunged into the lake. I took everything apart and used alcohol to dry them up, reprogrammed the ESC, and everthing went smooth except the lipo had to be replaced (old one died in the water).
MTDV is offline
Old 08-19-2007, 10:46 PM
ron_van_sommeren
homo ludens modelisticus
ron_van_sommeren's Avatar
MDTV, it's the motor that 'tell's' the controller when to switch.
Vriendelijke groeten Ron
ron_van_sommeren is offline
Old 10-13-2007, 07:22 PM
testpilot43
fly it like you stole it.
yep.......just yesterday my rimfire 1000 took a dump on me found out an hour later wire was on with one strand so i solderd it and works perfect now way down deep it was
testpilot43 is offline
Angler-Hi
General RC E-Heli Talk
13
09-17-2008 01:32 AM
punkindrublik
11-18-2007 05:16 PM
rz22g
04-16-2007 03:13 PM
punkindrublik
10-14-2006 04:03 PM
LT.Smash
07-08-2006 12:44 PM
Quick Reply: Brushless motor won't spin
Page generated in 0.06405 seconds with 13 queries
