superfly delta
Old 01-18-2006, 04:03 PM
scott w
scott w's Avatar
Default superfly delta
I have a superfly and have put 4 motors on it. 2 brushed and 2 brushless. Gws 350 and Gp21 (small outrunners). Have not had a successful flight. They go about 50 ft. and fall to the ground. You can do a hard discus launch and get another 20 ft. No the prop is not on backwards. The people I have talked to fly the superflea and seem to have good luck with it. Any ideas?
scott w is offline
Old 01-19-2006, 02:38 AM
Scott tell us more about the plane. What is your planes weight? Do you have any reflex in the elevators? What battery pack? More details? I have a twin and it is an excellent flyer.
Old 01-19-2006, 02:56 AM
scott w
scott w's Avatar
Default delta
Don: I don't have an elevator on this plane, it has elevons. This is my first delta and I do not know what or how reflex applies to this plane. I wish I could tell you the weight but I don't know. It is a stock superfly. You mentioned the fans. As far as I know fans are only on the superflea.
different plane, The people who have the superflea seem to like it. The superfly is another anamil. I put on their motor which I think is a 350 gear drive. It won't pull the wing. Battery pack is 1200 lipo. It is a mid-wing pusher tho. If I cool off I may try one more time to make it a puller. You can go to www.superfly.com and check them out. In the meantime I have ordered a wing from Speedwing. Thanks for the reply
scott w is offline
Old 01-19-2006, 09:53 PM
scott w
scott w's Avatar
Default Wrong address
I posted the wrong address for superfly. It should be www.superflyrc.com . Sorry for the mistake. Scott w.
scott w is offline
Fatcat1
08-08-2008 04:54 AM
aero_k
01-12-2008 07:52 PM
smitty
07-27-2007 02:50 AM
diverdon
06-15-2007 02:43 AM
DIALED/CHUCK
01-21-2006 04:53 PM
Quick Reply: superfly delta
Page generated in 0.07618 seconds with 13 queries
