Superfly problem
Old 11-07-2007, 05:44 PM
MARKZR7
Default Superfly problem
I just built a new SF. Added a new 3-c 20c 1300mah
This thing went crazy up down stalling Just barley
got back on the ground. bm 24 motor. Seems like lots of power
How far from the nose should the battery be or is it just to big???
I think my motor may have been off center a bit. fixed that
Any help would be great
Thanks mark
MARKZR7 is offline
Old 11-07-2007, 05:54 PM
pburt1975
Hotel California
pburt1975's Avatar
sounds like the COG needs to move more towards the nose of the plane. should help to level it out in flight. Or the battery is to large and making your COG impossible to locate properly
pburt1975 is offline
Old 11-07-2007, 06:19 PM
MARKZR7
not sure but others have said they use 3-cell 20c 1300
weight is 112 grams I went home so I didn't have a chance to
move the lipoly forward. I want to be sure on the problem. I just got
lucky getting it down without crash
MARKZR7 is offline
Old 11-07-2007, 09:08 PM
pburt1975
Hotel California
pburt1975's Avatar
According to the build instructions, the COG should be 9.25"-9.75" from the tip of the nose on the underside of the plane.
http://www.superflyrc.com/pdf/SuperFly.pdf
According to the site your battery is fine
2-3 cell 1200-1500 LiPoly
Old 11-07-2007, 09:19 PM
Schlepp
I fly my Superfly with anywhere from a 2s 1000 up to a 1700 3s and have the battery in the same spot regardless of its weight, the CG isn't real critical with this design, but I've been flying this thing for 2 years now so I'm pretty used to it.
Schlepp is offline
Old 11-07-2007, 09:56 PM
MARKZR7
I also have small micro servo's
about the size of hs55 what the heck is
going on
MARKZR7 is offline
Old 11-08-2007, 01:15 AM
lmopar69
Gravity Stinks!!
lmopar69's Avatar
How experienced of a flyer are you Mark? Could you just be over controlling it? What do you have your throws set at? The SF can be pretty sensative on the sticks.
Laine.
lmopar69 is offline
Old 11-08-2007, 01:24 AM
MARKZR7
This is my 3rd superfly
over 3-years I never had one do this
I also never had one with this much power
On scale of 1-10 I'm a 4
MARKZR7 is offline
Old 11-08-2007, 02:15 AM
lmopar69
Gravity Stinks!!
lmopar69's Avatar
Hmmmm. That is odd then. And its only acting up in the "pitch" axis?
lmopar69 is offline
Old 11-08-2007, 02:37 AM
Major Danger
Cascadia Militia
Major Danger's Avatar
Is this the first time you've used the micro servos Mark?
yes those 1300 3S lipos make this plane pretty potent compared to the 2 cells huh.
But from what you've discribed so far, it sounds like your servos cannot handle the large ailerons and the thrust from this motor. This is my assumption based on not knowing if this is the first time you've used these particular servos.
Drop the brand name and model number of the servos if you can. This may bear looking into.
By the way Mark WELCOME TO WATTFLYER !!!!
Major Danger is offline
Old 11-08-2007, 02:46 AM
MARKZR7
Yes it is the first time
I've given full power & they seem fine on the ground
They are from united hobby 8g servo
MARKZR7 is offline
Old 11-08-2007, 03:04 AM
lmopar69
Gravity Stinks!!
lmopar69's Avatar
What does it do power off in the air? Did you get to glide it at all?
lmopar69 is offline
Old 11-08-2007, 03:07 AM
Major Danger
Cascadia Militia
Ok Mark I think maybe we found a suspect on the potential problem. While they test out fine on the ground WOT, it's still not a full load on the ailerons. I think I'll make some time to browse around UH and see if I can find some torque data on their 8gram servos.
In the mean time Laines question is most important to assist identifying our suspects.
" What does it do power off in the air? Did you get to glide it at all? "
Old 11-08-2007, 03:24 AM
MARKZR7
Also major
The superfly did almost the same flying
at slow speed( no control)
MARKZR7 is offline
Old 11-08-2007, 03:25 AM
MARKZR7
very little even at slow speed
MARKZR7 is offline
Old 11-08-2007, 03:27 AM
lmopar69
Gravity Stinks!!
lmopar69's Avatar
well, that is strange. Where did you have it balanced at?
lmopar69 is offline
Fatcat1
08-08-2008 04:54 AM
MARKZR7
02-13-2008 01:56 PM
MARKZR7
11-13-2007 07:23 AM
MARKZR7
09-27-2007 04:12 AM
scott w
01-19-2006 09:53 PM
Quick Reply: Superfly problem
Page generated in 0.10979 seconds with 13 queries
