Need Lift on Rhythm Bipe
Old 07-21-2008, 02:41 AM
mtuhoop24
mtuhoop24's Avatar
Default Need Lift on Rhythm Bipe
I just bought a Rhythm Bipe from Hobby people. It is great and the weight is perfect. I have a small motor in it with a 3s 11.1v 730 battery. Plane looks great.
The problem is that it won't get off the ground. I have plenty of power. It really scoots across the parking lot. I have at least 1.25" of up elevator but it won't get off the ground.
I have flown it in a head wind and it did take off but the wind was too strong and I had to land it right away. Tonight I went out and it was dead still - no wind. It just zoom across the parking lot at a high rate of speed.
Could I have too much down thrust on the motor? I believe I have the motor mount flush to the bulkhead...........
Any ideas??
Thanks.
mtuhoop24 is offline
Old 07-21-2008, 03:03 AM
ministeve2003
Class Clown
ministeve2003's Avatar
Mine's the same way... It seems to take quite a bit of space to take off.... I'm sure the 1.25 is a little low for elevator though.... I think Mines like 2inches or so... if you have a computer radio try changing it to as much throw as you can get (without putting 125% on tx... and then putting about 60-70% expo.... I do that with ailerons and rudder too... then setup low rates at say 70% throw with 20% expo...
all else fails, handlaunch it.... if trimmed it should fly great...
SK
ministeve2003 is offline
Old 07-21-2008, 05:20 AM
Larry3215
Look out for that tree!!!
Larry3215's Avatar
See if you can adjust the gear so you have a little more up attitude when its sitting on the ground. It should take off faster then.
Larry3215 is offline
Old 07-21-2008, 05:34 AM
ministeve2003
Class Clown
I was thinking the same thing, when I built mine in the first place I wanted to lower/raise the gear to give more ground clearance but I had issues with it flexing the wing.... I knew I should have just taken the time to fix it the way I wanted...lol
SK
Old 07-21-2008, 02:44 PM
mtuhoop24
mtuhoop24's Avatar
Thanks Guys.......I did adjust the motor mount to get a little more up lift. I think it was pointing down a little too much.
And the biggest revelation in all the post - Hand Launch!!!! I haven't done that with a plane in such a long time it didn't dawn on me!
Perfect. Hopefully if the wind is calm I will give it a try last night. I will let everyone know how it worked!
Thanks.
Old 07-21-2008, 05:24 PM
gzsfrk
gzsfrk's Avatar
Just hand launch the thing. It's a 3D flyer, for goodness sakes, and light as a feather.
I swear--some of you guys and your need for RoGs...
gzsfrk is offline
Old 07-21-2008, 05:42 PM
mtuhoop24
mtuhoop24's Avatar
Yes I got it..............I will do just that!
Old 07-22-2008, 02:23 PM
mtuhoop24
mtuhoop24's Avatar
Hand launched the bipe last night and it flew great. Had to trim it a little but once that happened it was great. Wind is a killer. It was very calm but as I got it up a little higher it was slightly scary.
Now I just need to learn some more 3d moves and I will be set!
Thanks for all the help!
Old 07-22-2008, 04:06 PM
ministeve2003
Class Clown
what kind of trim settings are you using?
my new fav settings are (highest holes out on servo and innermost on control horn) 100% throw rates, with 70% expo, and for low rates 70% throw with 20% expo
anyone got any better setup rates I should try?
SK
Old 07-22-2008, 05:25 PM
mtuhoop24
mtuhoop24's Avatar
I am using the outermost on both the servo and control horn. I need to move my control horn to the inner most on my elevator and rudder. The ailerons are fine!
I have 100% Throw and 35% exp.
Old 07-22-2008, 05:33 PM
TDisaster
TDisaster's Avatar
SK
You need much less expo. I have HUGE throws on some of my 3D stuff and 25% expo at most. The plane must fly mushy as all heck!
TDisaster is offline
Old 07-22-2008, 05:40 PM
ministeve2003
Class Clown
mushy, huh... nope... but I do have just about the max throws you could have, almost...LOL
you ever seen a 48" profile roll 3-4 times a second?
SK
Old 07-22-2008, 05:42 PM
TDisaster
TDisaster's Avatar
Yup. But I make very small stick movements, so I use little expo, depending on the plane I don't use any. But you must bang the sticks, so to speak .
Old 07-22-2008, 05:43 PM
ministeve2003
Class Clown
I used to use no expo, I hated it infact, but then I realized, to compensate for no expo, I wasn't putting high enough rates,
SK
Old 07-22-2008, 05:44 PM
TDisaster
TDisaster's Avatar
SK
Oh, I have my rates maxed out on every plane I own .
Old 07-22-2008, 05:45 PM
ministeve2003
Class Clown
like I said 70/20 is low rates, thats prob about the same as yours... My 48" profile has those arm extensions....
Course I could still be doing it the wrong way...LOL
SK
Old 07-22-2008, 05:47 PM
TDisaster
TDisaster's Avatar
SK
Whats a low rate?
pstrdenver
3D Flying
192
11-21-2009 09:14 PM
aviatordave
Basement Bargains
59
12-01-2008 05:49 PM
neilg.
E-Flite Helicopters
12
08-05-2008 01:40 AM
3D Romeo
Foamies
10
05-25-2008 05:16 AM
quailbird
Aerial Photography
11
07-01-2007 02:08 PM
Quick Reply: Need Lift on Rhythm Bipe
Page generated in 0.12273 seconds with 13 queries
