Fairchild PT-19 Cornell; DollarTree Foamboard & Dow PBIII - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 05-16-2010, 06:48 PM
Voyager2lcats
Friend Across the Water
Voyager2lcats's Avatar
Default Fairchild PT-19 Cornell; DollarTree Foamboard & Dow PBIII
I posted some teasers of this plane I am scratch building on some other threads, but here is the build thread (finally). I built this from a combination of plans from the Pica PT-19 kit (thanks to Tom the Grasshopper), Sterling plans (thanks to Paul aka pd1), and RCG for the Gene Rogers plans. Here are tiles of the Sterling and Gene Rogers plans:
Name:	Gene Rogers Fuselage Plans.jpg
ID:	127636   Click image for larger version
Name:	Gene Rogers Wings Plans.jpg
ID:	127637   Click image for larger version
ID:	127638   Click image for larger version
ID:	127639   Click image for larger version
ID:	127641   Click image for larger version
ID:	127642   Click image for larger version
ID:	127643   Click image for larger version
ID:	127644   Click image for larger version
ID:	127647   Click image for larger version
ID:	127648   Click image for larger version
ID:	127649   Click image for larger version
ID:	127650   Click image for larger version
ID:	127652   Click image for larger version
Voyager2lcats is offline
Old 05-16-2010, 07:08 PM
Voyager2lcats
Default Getting started.
This was a "fits and starts" type of build as I had to reconcile the three plans against each other. I used the Pica plans as a guide for the internal foamboard "skeleton" as I felt it was the least scale but essentially correct in model alignment and it illustrated servo locations- for battery, motor, and ESC locations I took some hints from Tom the Grasshopper's Pica PT-19 balsa build thread (look here: http://www.wattflyer.com/forums/showthread.php?t=29386). I used the Gene Rogers Plans for the fuselage and tail surfaces, while I used the Sterling plans for the wing size (big). I did something I have not seen anyone do before (I am sure someone has)- I took measurements from the Gene Rogers plans using 1/4" as my offset for the blue foam thickness, and used MS Powerpoint's drawing feature to make ovoid fuselage cross sections from the measurements. I have included this for those who might be tempted to try and build this model.
Name:	Pica PT-19 plans.jpg
ID:	127664   Click image for larger version
ID:	127665   Click image for larger version
Name:	Fuselage dry fit on Pica plans.jpg
ID:	127666   Click image for larger version
Name:	Gene Rogers' fuselage and elevator plus Sterling Wings.JPG
ID:	127667   Click image for larger version
Name:	Gorilla gluing blue foam wing together.jpg
Name:	Second wing on plans.jpg
ID:	127669   Click image for larger version
Name:	Wing and Fusleage on plans.jpg
ID:	127670   Click image for larger version
Name:	Blue foam for nose.JPG
ID:	127671   Click image for larger version
ID:	127672   Click image for larger version
Name:	PT-19 Bulkheads.jpg
Name:	Where the Firewall goes.JPG
ID:	127677   Click image for larger version
Name:	Starting to look like PT-19.JPG
ID:	127678   Click image for larger version
ID:	127679   Click image for larger version
Name:	Gluing on more tail foam.JPG
ID:	127680   Click image for larger version
Name:	Fit to nose.JPG
ID:	128342   Click image for larger version
Name:	Sterling plan wings.jpg
Old 05-18-2010, 12:35 AM
Voyager2lcats
Cool Heat forming a plastic cowl
I had not really tried this before, but because my good friend Barry (baz49exe) encouraged me with his heat forming thread, I decided to have a try. Four plastic messes later I had a very nice heat-formed cowl. I started with two pieces of 2" x 4" pine blocks which I glued together, traced the top view and side view onto, and used my electric hand sander to shape it as a plug. Then I went to the unused sandbox in the back yard, wet the sand with a glass of water, scooped out a hole, pushed the pine plug in, covered it with sand around the outside up to the "back" side, gently pulled it out of the sand, and poured a 4 parts plaster of paris to 1 part water mix into it and let set for 2 hours. Voila! Rough plaster plug for heat forming.
ID:	127854   Click image for larger version
ID:	127855   Click image for larger version
ID:	127856   Click image for larger version
Name:	Cowl Motor Magnets.jpg
ID:	127857   Click image for larger version
ID:	127859   Click image for larger version
Name:	Motor Mount.jpg
ID:	128343   Click image for larger version
Name:	Motor inside Cowl.jpg
ID:	128344   Click image for larger version
Old 05-19-2010, 12:19 AM
Voyager2lcats
Default What does it look like with the electronics?
You have have seen the results of my heat-formed cowling. Now take a look at how I placed the firewall and motor mount as well as servos, ESC, and motor.
ID:	127943   Click image for larger version
ID:	127944   Click image for larger version
ID:	127945   Click image for larger version
ID:	127946   Click image for larger version
Old 05-19-2010, 01:08 AM
capn chaos
capn chaos's Avatar
Default WOW
Bob,
That looks absolutely fantastic. I have been wanting to try a similar build, 1/5-1/6 Ryan using the same technique, just divinicell instead of FFfoam.
Pretty clever and looks super light. Cant wait to see it finished off. Will be down in your area (Columbia) over the 4th for a few days. Will PM you with timing later and maybe get out to fort J to fly.
Bob, the other
capn chaos is offline
Old 05-19-2010, 05:59 PM
Voyager2lcats
Thanks Bob. This is great stuff- Dow Protection Board III and DollarTree Foamboard. Relatively cheap and easy to find. July 4th will be impossible at Fort Jackson as they will be setting up Hilton Field for the night's fireworks. Traffic will be a complete nightmare.
Other Bob
Old 05-19-2010, 06:18 PM
capn chaos
capn chaos's Avatar
Thanks for that heads up on the 4th. I will be down around the 1st or 2nd and will come back this way somewhere around the 6th. My 4th is annual family reunion anyway...whole day is pretty much spoken for. Might have to come up with a quick seaplane as the picnic is at Lake Murray where we all grew up...what ever that "grow up" thing means
Do like your build...
Bob-2
Old 05-20-2010, 05:20 PM
Voyager2lcats
Default More pictures.
I don't have a theme here other than "look what I did"; blue foam wrapped and glued around formers on fuselage, tail dry fit for perspective, 20 Amp ESC and 1000 mAh LiPo battery added. Balance is nose heavy at this point, but more hardware will be going aft. This is my first real effort at torque rod ailerons and they work pretty nicely. I would say in retrospect I should have made the uprights shorter so I would have had more deflection for the ailerons, but it will keep me from overcorrecting.
P.S. I don't know why the pictures are offset, but maybe someone can suggest how to edit this post.
ID:	128118   Click image for larger version
ID:	128119   Click image for larger version
ID:	128120   Click image for larger version
ID:	128121   Click image for larger version
ID:	128123   Click image for larger version
ID:	128124   Click image for larger version
ID:	128125   Click image for larger version
ID:	128126   Click image for larger version
Old 05-20-2010, 11:56 PM
Voyager2lcats
Default Depron skin, landing gear mounts, and dinging.
I decided that the profile around the front of the fuselage was slightly unsatisfactory, so I added some 3 mm depron "skin" to smooth out the transition from cowl to fuselage. Hmm, so-so, but I am not done with it yet. I made some rectangular landing gear mounts from four pieces of 1/8" ply Gorilla glued together and then Gorilla glued into the wingspar and top skin of the wings. I have inflicted some wounds on the left wingtip (dropped it while carrying from table) and numerous small dings too numerous to illustrate. Left wingtip edge is now Gorilla glued in place and spackled followed by sanding. Needs another spackle job to really fine tune it. But not a major undertaking.
ID:	128147   Click image for larger version
ID:	128148   Click image for larger version
ID:	128149   Click image for larger version
ID:	128150   Click image for larger version
ID:	128152   Click image for larger version
ID:	128153   Click image for larger version
Old 05-23-2010, 12:31 AM
Voyager2lcats
Default Last of the current pictures.
Here is pretty much where this model stands at this point. It needs a lot of work to be more scale and finished in appearance. I have dry fit a 1/16" ply triangular tail wheel mounting plate and also the tail wheel without its servo horn and retaining ring (it's going to turn with the rudder). I will upload that picture when I get a chance (fingers crossed).
ID:	128347   Click image for larger version
ID:	128348   Click image for larger version
ID:	128349   Click image for larger version
ID:	128350   Click image for larger version
Old 05-24-2010, 06:29 AM
baz49exe
baz49exe's Avatar
This is a great build thread Bob, you put my efforts to shame old friend.
Having seen the plans posted especially the fuselage sections I am thinking that in the future ( after all the others which are stacking up ) I might have a go at this lovely little plane. I really also ought to try building with sheet depron having seen the great job which you are doing with it. I can't wait to see this little beauty fly.
Barry
baz49exe is offline
Old 05-24-2010, 04:22 PM
Voyager2lcats
Barry
Thank you Barry. The plans are excellent- that is what made this difficult- deciding which to use, so I used aspects of ALL. Depron is an outstanding RC model building material so you will not be disappointed. It seems to be more popular in Europe than in the US (except for take-away plates and the like). I have seen some nice rolled depron called selotech (I think that's what it's called).
Old 05-27-2010, 08:58 PM
baz49exe
baz49exe's Avatar
A friend on our flying field has told me where I can get depron sheet. No excuses now.
baz49exe is offline
Old 05-28-2010, 01:56 AM
offtom
Megans Servant
offtom's Avatar
Great build so far. It puts my previous attempts and thoughts to shame.
I love the PT-19. It was the first CL plane I could actually fly.
I just have to know, the cowl forming. Is there a thread/build/advice/whatever etc on how to? That always something that just frustrates me to no end.
offtom is offline
Old 05-28-2010, 02:21 AM
capn chaos
capn chaos's Avatar
Bob,
Lookin good...Will it be ready by the end of June?? Would like to see that thing fly while I'm down in "center city"
Great progress.
Tutherbob
Old 05-28-2010, 03:57 PM
Voyager2lcats
Default Check this out.
Tom, I am going to give you a teaser and two threads. One is a sticky (http://www.wattflyer.com/forums/show...658#post722658) which my post (http://www.wattflyer.com/forums/show...8&postcount=13) is in and the other is a thread (http://www.wattflyer.com/forums/showthread.php?t=36104) by Barry (baz49exe) which has an excellent home-made jig you can make for cowls and canopies. Barry and I use heat guns and luck/skill (in that order) to make canopies and cowls. It works. Okay, here is the holy grail of heat forming: Demon-Leather's posts on RCG (http://www.rcgroups.com/forums/showt...=246240&page=2). Anyone who wants to do basic, easy-to-do-at-home heat forming should view this thread/posts.
Old 05-28-2010, 04:01 PM
Voyager2lcats
Originally Posted by capn chaos View Post
Bob,
Great progress.
Tutherbob
Bob, I could fly it right now (I would need tape to keep the cockpit on!). Tail wheel is waiting for me to permanently mount it. I think the end of June is a very realistic goal. Now as for flying- I think I can give a semblance of that. LOL.
Columbia Bob
Old 06-06-2010, 05:44 PM
Voyager2lcats
Smile No pictures today, but I will edit and post tonight
I added some depron panels to the front fuselage from the firewall back to the leading edge of the wing fairings. I think it looks really scale! I don't have the pictures yet (see this title), but I will upload them tonight. I have to give a plug to Erik (TV Casualty) here. I started a thread on his web site about this build and he did some SketchUp preliminary plans that look absolutely fantastic. Check out his web site @: http://foamcasualty.com/. You won't regret it
Old 06-08-2010, 07:13 AM
baz49exe
baz49exe's Avatar
Looking forward to the pics Bob.
baz49exe is offline
Old 06-08-2010, 04:01 PM
Voyager2lcats
Barry, so am I! LOL. Now if I just take them and post them.
Old 06-17-2010, 11:57 PM
Voyager2lcats
Default Most recent (i.e. real time) photos.
I have some new pictures of the build progress. You can't really tell, but the wings are covered on top with silk. The spackle is very smooth despite the splotchy look on the wing tops. I can't wait to paint the wings that bright yellow.
ID:	130548   Click image for larger version
Old 06-18-2010, 02:01 AM
offtom
Megans Servant
offtom's Avatar
Whoa!!.........................That is so cool.
I so want to build one of these.........Ever since my Cox .049 PT-19.
I need to finish my other projects first. Great job with your build. I am very impressed.
offtom is offline
Old 06-18-2010, 04:08 PM
Voyager2lcats
Thanks Tom. I have not flown a PT-19 since I crashed my Cox .049 CL PT-19 on my 11th birthday. Totaled. The PT-19 just looks right, if you know what I mean.
Old 06-18-2010, 11:42 PM
Voyager2lcats
Default Just some detail pictures.
These are some pictures of the rear underside showing how I used plywood for bracing and mount of the tail wheel (yes, it will be steerable). I need a smaller clamp for the inside of the wheel wire to hold it inside the fuselage. Looks like a visit to the LHS will occur. The other pics are pretty much overviews of the tail construction. I copied the ply elevator link from the Pica plans as it serves as a mount point for the elevator horn and aligning the elevator halves.
ID:	130602   Click image for larger version
ID:	130603   Click image for larger version
ID:	130604   Click image for larger version
ID:	130605   Click image for larger version
Old 07-07-2010, 01:01 AM
Voyager2lcats
Default Thanks to Captain Chaos; New pictures.
I met my first WattFlyer member this past week and what a pleasant fellow- Captain Chaos (aka "Tuther Bob"). Well Bob was the first Watthead to actually see this little gem. I hope you had a safe trip to Maryland.
Now the pictures are from yesterday, so nothing revolutionary here, but spackling is proceeding as only spackling can- slowly. My thread (and building) definitely need the bump.
Bob
ID:	131424   Click image for larger version
ID:	131425   Click image for larger version
ID:	131426   Click image for larger version
Quick Reply: Fairchild PT-19 Cornell; DollarTree Foamboard & Dow PBIII
Page generated in 0.14620 seconds with 98 queries
