Slow loading times? - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Support & Suggestions If you need tech support post your question here or site suggestions too.
Slow loading times?
Old 05-27-2008, 08:38 PM
aviatordave
aviatordave's Avatar
Default Slow loading times?
Has anyone else experienced long wait times for pages to load up? For me it is
D O G ...... S L O W ......
Other sites load fast, and I'm on broadband....
aviatordave is offline
Old 05-27-2008, 08:45 PM
Grasshopper
Some Assembly Required
Grasshopper's Avatar
Mine have been loading fine.
Grasshopper is offline
Old 05-28-2008, 03:03 AM
Airhead
Redneck Member
Airhead's Avatar
I think mine have been loading well.....
Airhead is offline
Old 05-28-2008, 03:09 AM
Mike Parsons
Penguins still can't fly
Mike Parsons's Avatar
What OS are you using again Dave?
I am browsing on both FF and IE7 and while FF is noticeably faster, IE seems to be loading normally.
Mike Parsons is offline
Old 05-28-2008, 03:11 AM
gfdengine204
gfdengine204's Avatar
Well, FF is NATURALLY faster.....
FWIW, mine is browsing fast.....
gfdengine204 is offline
Old 05-28-2008, 04:00 AM
Rabbitcreekok
Rabbitcreekok's Avatar
Mine have been slow in loading. Compared to that other site, RCG, WattFlyer is about 1/3 the speed, and that is with all their ads. I am using IE7 and am on broadband also. I thought it was just the increased use here.
Rabbitcreekok is offline
Old 05-28-2008, 04:35 AM
Rabbitcreekok
I just did a little survey.
From the time I click on the link in the email until the thread loads on WattFlyer takes between 13 to 15 seconds. RCG takes around 3 seconds for the same deal.
Checked it several times.
Old 05-28-2008, 04:41 AM
Grasshopper
I just logged in on FF and man is it a lot faster. I thought IE was plenty fast but FF is almost instantaneous. The screen resolution quality is not as good on FF for some reason though.
Old 05-28-2008, 05:21 AM
Mike Parsons
Ill have Dan take a look.
Old 05-28-2008, 05:30 AM
HeliG
T-Rex Pilot
HeliG's Avatar
I thought things were slow and then when I loaded this thread I knew for sure...
SSSSSSSSSSLLLLLLLLLLOOOOOOOOOOWWWWWWWWWW.
HeliG is offline
Old 05-28-2008, 06:08 AM
Kosh
Kosh's Avatar
Works normal on my end with a DSL line and I'm looking at about a 1.5 second load time.
Kosh is offline
Old 05-28-2008, 06:46 AM
aviatordave
Wow Mike! Mess with my mind!
You changed the thread.
I'm using IE7 right now, seems whenever you do a system upgrade it makes me slow. Lets see if ghomer has the same symptoms. Weird that I get it all the time.
Does location have anything to do with this? Ghomer is only a few hours from me...
Old 05-28-2008, 06:59 PM
admin
admin's Avatar
can you do a traceroute to www.wattflyer.com to see if it is network related?
admin is offline
Old 05-28-2008, 07:09 PM
Bub Steve
Bub Steve's Avatar
admin::Mine just got twice as fast in the last few days, did ya fix something,? or just trick it out ?? thanks for the "boost" bub, stevePS admin a funny screen name, HaHaa ( just yank'in your chain)
Bub Steve is offline
Old 05-28-2008, 07:17 PM
Mike Parsons
Sorry about that. I wanted to get it in the SS forum for more attention.
Dave,
Can you load the homepage http://www.wattflyer.com and then scroll to the very bottom of the page. It should give you a Page loaded message and tell what time and how many queries it took
I.e
Page generated in 0.16734 seconds with 66 queries (1 queries for uncached templates) [Server Loads: 0.42 0.46 : 0.52]
Old 05-28-2008, 07:46 PM
aviatordave
Page generated in 0.62828 seconds with 22 queries
.6 seconds seems quite fast, but it loads with almost the entire page and hangs out for awhile at the end. Whatever the last few things that get loaded is what stalls my pc (IMO).
Old 05-28-2008, 07:49 PM
Biplane Murphy
2 Wings, Twice The Fun
Biplane Murphy's Avatar
I hear "Yawn...Iowa" has the slowest Broadband in the country.........
Biplane Murphy is offline
Old 05-28-2008, 09:39 PM
aviatordave
We run our internet through the barbed wire fences. Doesnt everybody?
Old 05-28-2008, 10:25 PM
Mike Parsons
I filter mine through a spaghetti colander
Old 05-29-2008, 05:31 AM
Rabbitcreekok
Here in Oklahoma we call it Bob Wahr. Mine is still slow and RCG is still fast.
Old 05-29-2008, 05:46 PM
Mike Parsons
I have tested extensively with IE 6 and 7 and dont have the lag that you guys are experiencing. We will keep testing.
I recorded it below.
recorded load times on IE wmv 5 mb
Old 05-29-2008, 06:12 PM
aviatordave
Mike,
Weird, seems to be working fine now. I didnt change anything here. I tried the 'child of default setting' and that seemed to be a bit laggy than reg default.
Hope that helps-
Old 05-29-2008, 06:30 PM
Mike Parsons
Mike,
Hope that helps-
Well..now I am thoroughly confused
Old 05-29-2008, 06:36 PM
aviatordave
Let me take that back.
My PC was going through an update when I did that, my bad. I tried the child mode again with nothing running and its the same speed as default.
I shouldnt eat lunch and type at the same time.....
Old 05-29-2008, 06:45 PM
gfdengine204
Dave,
Does it run slow only when Icehouse is around?
(Or maybe that would make it seem to run real fast.....hmmmmm)
Quick Reply: Slow loading times?
Page generated in 0.16990 seconds with 14 queries
