OK to use generic ACadapter on e-Sky LiPo charger? - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 02-15-2008, 05:44 PM
isaksp00
Default OK to use generic ACadapter on e-Sky LiPo charger?
I have a cheap ($10 model) e-Sky LiPo charger on order, comes with cables for 12V battery input but no AC adapter. I have a few generic AC-DC adapters (black bricks) rated at 12V around the house, a few of which are in the 1Amp range (per the label). Assuming the round plug fits, and has correct polarity, I am wondering if these should work and are safe to use. One worry: the charger says it is rated for 12-15V input, and 2 of these generic adapters measure around 15.5 to 15.8 volts DC output. I am wondering if the voltage is only higher without load, or would these damage the charger?
Thanks!
isaksp00 is offline
Old 02-15-2008, 09:44 PM
Rodneh
It is highly unlikely to work, or if it kinda works, will not be reliable. Most of these wall warts are not well regulated if they have any regulation at all. Most are just half or full wave rectifiers with no filtering and use the internal impedance of the transformer windings to limit the voltage and current. It could possibly even damage your charger but that is not likely.
Rodneh is offline
Old 02-15-2008, 09:50 PM
isaksp00
Boy, you folks are fast!
Thanks for this. I know I can buy a 12V brick from Radio Shack - any idea if this is any good for the charger? If not, do you know who sells one appropriate for it (I have not found any web site yet that seems to be the tech support and "where to find a dealer" for the e-Sky manufacturer)?
isaksp00 is offline
Old 02-15-2008, 10:45 PM
jdetray
As Rodneh said, you want a regulated 12V DC power supply. The actual output of such a supply is often 13.8V, the voltage of a typical automobile battery.
Charging is not 100% efficient, so the current rating of the power supply needs to be substantially greater than the maximum charge rate you will be using. If your charge rate is, say, 1 Amp, then you'll want a power supply that is at least 2 or 3 Amps.
But do yourself a favor and get a power supply that is larger than your present need. You will never regret owning a good 12V power supply. I suggest a minimum current rating of 10 Amps.
One popular brand is Pyramid power supplies, which are widely available online. Radio Shack has some decent units, too.
- Jeff
jdetray is offline
Marc
11-30-2008 06:01 PM
Marc
ParkFlyers
10-31-2008 04:22 PM
lesman
08-24-2008 04:03 PM
pburt1975
12
03-06-2008 06:07 AM
Sam_K
Eagle Tree Systems, LLC discussion
02-05-2008 01:24 AM
Quick Reply: OK to use generic ACadapter on e-Sky LiPo charger?
Page generated in 0.05393 seconds with 13 queries
