Receiver heat sensor - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 07-14-2007, 06:23 PM
rgfitz
Default Receiver heat sensor
I searched these forums for "heat sensor" and found:
"Some ESC's have a temperature sensor to prevent this"
I assume ESC means the receiver/servo package in the aircraft.
Anyway, I flew my Firebird Outlaw this morning and was timing the flights and getting used to flying in a very light breeze. The batteries run about 9 minutes. When I put in the third battery the props would turn momentarily but that was it. The fuselage felt slightly warm so my guess is that there is a temperature sensor on the circuit board of this cheap little Hobbyzone airplane.
When I got home I checked the third battery to make sure it was fully charged and the motors ran fine.
rgfitz is offline
Old 07-14-2007, 06:27 PM
gfdengine204
gfdengine204's Avatar
ESC = Electronic Speed Control
gfdengine204 is offline
Old 07-15-2007, 05:08 PM
rgfitz
Default 30 minutes to cool off
Apparently two batteries worth of flying then 30 min of cool down is required for the speed control. The air temperature when I fly is about 72 deg F.
I drilled a 3/8 in hole in the battery cover and two in the pylon just below the wing for ventilation. It might not make much difference.
That thin plastic sure is tough.
rgfitz is offline
Old 07-16-2007, 03:56 PM
rgfitz
Default It is the battery stupid
With three identical batteries I apparently used the bum one last for two days of flying.
I finally marked them and found the bad one.
rgfitz is offline
Sam_K
Eagle Tree Systems, LLC discussion
02-05-2008 01:24 AM
Moonwalker
11-02-2007 08:52 PM
billpa
05-28-2007 04:06 AM
billpa
New Product Announcements
12-04-2006 05:35 AM
RcOre
Aerial Photography
08-18-2005 12:43 AM
Quick Reply: Receiver heat sensor
Page generated in 0.05514 seconds with 13 queries
